Performance parts cat
- 340GLT
Prob a slightly diff shape but i cant see it being a problem using it, as the box would definately bolt straight on then!!! Its up to you, as i said, its no use to me now!!!
Cheers Adam
Cheers Adam
Dai I want whatever setup you suggest for drifting i.e:
Spax rear dampers then whatever inch lowering blocks that will be fine with 175/50/13's
Lowering springs again whatever drop and poundage you think for me.
Are those front dampers out of development yet? If not any suggestions for others?
Don't drift faster than angels can fly
I need to update this thread. A few changes such as the rear engine mount I have found the front ones will fit with very simple mods.
I like the 3" exhaust system!
If I use the biggest 3" silencer (Turbo?) and no other silencer at the back will the car be loud? How well does it silence the roar? Is is way better than the standard Volvo one?
What parts will I need for a front to back 3" SS system?
Is this right?
Straight pipe (1000/500mm?): 11.97 / 23.04
Turbo silencer: 97.56
2 x 90* bend (?): 39.56
Over axle bend: 46.06
Straight Length 500mm: 11.97
Don't care about Chromed or polisched tailpipes...
What's a compensator?
Do you have exhaust parts like this for a 740 2.3 16V Estate aswell?
Is this right?
Your list of bits is about right. You are going to need some bends as well and you probably have to bent some of the pipes just a little to get it in.
A compensator is a coupling that alaws the exhaust to twist without fracturing. Reduces strain from engine twisting on the exhaust.
We do a full cat back system for the 740 16v.
On a turbo system 1 box should be enough to keep it at a sensible noise level.
Eyeball-360
Hunny I'm Home
I can get +1" springs made no problems. Let me know if it is for a 1.4 1.7 or 360. Also worth checking what your current ride hight is. This is measured from the wheel centre to the top of the outer wheel arch. These positions are used as they are constant regardles of wheel tyre size.
If you need to contact me its bect to send me a email for quickest respons.
Thanks
Thanks
