Clutch change help??
PIMP
Post by PIMP »
scrap it!!!!! in labour alone i think you could have bought three more!!!!! lol
just jokin fella!!........
hope you get it sorted for sats driftin!!
Jay340
Post by Jay340 »
:shock: , as soon as i finish work at 2 I will be straight on it, if i can get the BH off inside an hour and get the clutch swapped and back on inside another hour then i will plough on and get it done for tonight, if not i will finish it tomorrow and meet up for a mid week sesh as im getting withdrawel symptoms.... :evil:
Mine (B14) was a piece of piss...
...except that one of the engine mount bolts was rounded, making it impossible to remove the engine mount (without drilling it, as far as I could see)...making it VERY hard to get the bellhousing off! :(
Clutch is in....just need to reassemble.
Jay340
Post by Jay340 »
foggyjames wrote:Mine (B14) was a piece of piss...
Know that I know what to do, this is a fairly easy clutch change.. what makes it really hard is the fact that the shop sold me the wrong clutch and I cant change it till tomorrow.
so another day without being able to do anything... should now be done tomorrow....
What is wrong with the one they sold you?
Jay340
Post by Jay340 »
its a 26 spline clutch plate rather than a 20 spline plate, so it doesn't fit over the bellhousing.
the 340 has 2 clutch options
Same problem as what I had :(
Jay340
Post by Jay340 »
a right pain in the arse
shimon340
Post by shimon340 »
2 clutch options??? two options for the 1.4??
was there a year it changed?
bit worrying.... Im working at my friends workshop to do the clutch on my J reg 340. I got a Ferrodo clutch off ebay... I hope it wont be one of those situations where the clutch is dismantled and I realise Ive got the wrong part..............
got any more info on these two options guys?
shimon
Enjoy your 300s
Relax, they're talking about the 1.7
Jay340
Post by Jay340 »
foggyjames wrote:Relax, they're talking about the 1.7
Tis the 1.7
shimon340
Post by shimon340 »
PHEW!!
but... did the clutch change occur when the 'late 1.7' was launched... ie the one with the different cambelt... there is a post here about two different types of cam belt for the 1.7... one for the early engines with the metal cambelt comver and one for the engines with a plastic? cover
Im interested in getting rid of the cambelt on my 1.7 and fitting a chain drive
The only reason manufacturers moved to cambelts instead of chains was because belts are quieter and I guess cheaper also but they are a hassle when you are trying to keep an old car!! coz they only have a finite shelf life so you cant keep some in a cupboard for use in years time coz belts need changing due to milage OR age.......... just a random extra thought there!!
The 1.7 was a bit of an after thought for the 340... the car wasnt designed from the outset with the intention of it being a 1.7.... so the 1.7s are bit un-volvo in some areas such as clutch and steering rack change... ie these jobs arent as easy with things not being so easy to get to like on the 1.4 or other bigger volvos... still compared to most cars the 1.7 is still good to work on..
good luck with the clutch!
shimon
Enjoy your 300s
No it was not with the engine type cahnge but came a little later on 1990 models but the books seem to list 89 models as having the later clutch. The the 89's I know of use the early coars spline one.
