Page 4 of 9
Posted: 03 Jan 2005 10:05 am
by huskyracer
The tdc pickup holes can be carefully filed out to alow the sensor to be moved back or forward with a corresponding change in ignition timing. This is a trick we used on the renault 5 turbos, I think all the volvos with renix have the same type sensor. a lot of the volvos have timing settings for fuel with the same octaine rating as donkey wee so it should work quite well,just listen out for any pinking
Posted: 03 Jan 2005 05:23 pm
That sounds about right! Our V40 (turbo!) can run on 91RON fuel...nuts!
Posted: 06 Jan 2005 04:23 pm
by 340customizer
Something like this?
I also heard that you could swith those wires?
That would get you an 4 degrees pre ignision?
Was that was a GTT trick to?
I'll get my car on a Dyno rolling road next thursday.
Greets
Andries
Posted: 12 Jan 2005 08:35 pm
by huskyracer
Top crank sensor modding there, couldn't have done it better myself!!! Dont know about swapping the wires round, but results could easily be checked with a timing light, If you try this, let us know how you get on.
Havent been posting for a few days, decided to get in the garage and do some work on the engine instead of talking about it. Have built the bottom end of the engine, all std 440 turbo, apart from 300 sump and engine mount brackets, The 300 spigot bearing goes straight in the 440 crank,
The clutch has a different number of splines, so have used stock 300 centre plate, with 440 turbo cover plate. The engine wont fit as is as the throttle housing would be 4 inches INSIDE the heater
Also, the exhaust manifold locates the turbo squarely in the middle of the bake master cylinder
I have cut the manifold off at the flanges and turned it up side down wich puts the turbo at the front, I am not to sure what to do with the inlet side yet. Phoned recoprop today, he can make a steel prop with 2 uj's £175 plus vat he says he's done loads over the years so thats that problem sorted will keep you posted on further progress.
Posted: 12 Jan 2005 09:59 pm
Excellent news on the progress! Would an early-style heater box help?
Posted: 15 Jan 2005 02:05 am
by 340customizer
Ooops i just found out that you can change the posision of the black thingy on the steel plate thingy just by tapping it with a hammer
Posted: 15 Jan 2005 10:12 am
by jtbo
I tried that, but hole below black thingy is same shape as that blackthingy is and therefore it could not move. Maybe this is difference in 340 1.4 vs. 360 ?
Posted: 15 Jan 2005 06:35 pm
by Geez
Posted: 15 Jan 2005 07:20 pm
It will indeed - and it's great that it's one of 'our' cars! Wilder things have been done, but as it stands it'll be the hottest road-legal 300 in the country!
Posted: 23 Jan 2005 07:57 pm
by huskyracer
Posted: 23 Jan 2005 08:18 pm
huskyracer wrote:enough for about 160 bhp, I dont think this will be enough
Damn, I'm liking the sound of this project
That is going to be one pretty hot 340
Looks like you're getting on with it quickly!
Posted: 23 Jan 2005 08:27 pm
Have you encountered Megasquirt? Programmable (plug in your laptop!)EMS (for both fuel and ignition), and the last group buy on Turbobricks was selling an assembled kit for about £150. It's a bit DIY, but is all well documented. You could get it installed and running for £250-300, easily.
Posted: 23 Jan 2005 08:46 pm
by huskyracer
The omex I already have, it was originaly going to be fitted to my beetle but it's been in the bottom of my wardrobe for about two years now, as the plans for my bug keep getting wilder the omex costs £500 ish but it is very user friendly, nice to map and does everything you could wish for in a £500 ecu. I realy didnt want to have to go this far with management as the ecu alone has effectively over doubled the price of the project but as it was 'in stock' I suppose it would be rude not to. The megasquirt stuff sounds interesting, especialy the price (is it jtbo thats got one?) where can i get more info on it?
Posted: 23 Jan 2005 09:03 pm
by jtbo
Here is forum:
http://www.msefi.com/
Here is the 'thing':
http://www.bgsoflex.com/megasquirt.html
I have one, just waiting to get fuelpump and few sensors and also Weller welder(word?) needed
As I need to change almost everything from intake side it costs bit more, but if you have already working fuel injection costs will be low as then no need for new manifold, injectors etc.
Some alternate megasquirt stuff goes here:
http://www.megasquirt.info/ms2/EDIS.htm
http://megasquirt.sourceforge.net/extra/
As you can see possibilites are almost unlimited because source code is free and lot of new stuff can be applied with just downloading new software and that part is free
Some require little hardware changes, but still much better than buying whole new unit
Posted: 23 Jan 2005 09:22 pm
by huskyracer
Wow, thats quite a piece of kit
What type and spec senders do you need? i might be able to help
iain
