The other alloys
V6 Man
Post by V6 Man »
The main problem with 0-60 times is that they rely too much on power from rest, not mid-range pull, and gearing - some cars need a 2nd to 3rd shift just before 60 that slows the time by a second or two.
A 1/4 mile allows such factors to be less important and allows the mid-range grunt of the diesel to come into play.
Dave
Post by Dave »
Could I backtrack a little and ask a basic simple question (Forgive me, I once owned a Mini Metro (Mk2!!!) )
What wheels will fit a 300 series? Volvo or otherwise, preferably keeping the same 14"rim size
Ta :)
Dave
bodejodel
Post by bodejodel »
Almost everything with 4 x 100 bolt holes and a ET wich does not differ to much...
Jeroen
If you want something a bit more modern than the 300 series rims, I'd take a look at the 400 series ones - there are literally dozens of styles, although only a few are common.
cam740
Post by cam740 »
bodejodel wrote:Almost everything with 4 x 100 bolt holes and a ET wich does not differ to much...
i've been trying to find out what the ET is on the 360 but no such luck!!
any clues guys???
bodejodel
Post by bodejodel »
The ET on my mk 2 GLT rims is 40.
Jeroen
cam740
Post by cam740 »
bodejodel wrote:The ET on my mk 2 GLT rims is 40.
Legend!!!
Its hard enough finding aftermarket alloys knowing all the offset details let alone with only HALF the details!!!
Post by redline »
nova rims are et 40-45
cam740
Post by cam740 »
i can get some nice new 16s with an ET of 35 - will they fit?????
Damir130
Post by Damir130 »
Just fine, provided that you can afford the low profile tires that are needed to get the circumference back to whats needed.
Scuderia Rollator: Racing fridges and tractors
1988 Volvo 360 trackbeater and money eater
1983 Toyota AE86 GT-coupe - moneypit numbero dos
1985 Toyota AE86 trueno - drift only
1972 Toyota Corolla KE25 coupe
17s can be fitted and retain the original wheel size if you use skinny enough tyres...but 16s are probably a better choice :)
cam740
Post by cam740 »
foggyjames wrote:17s can be fitted and retain the original wheel size if you use skinny enough tyres...but 16s are probably a better choice :)
that was what i was thinking as well James - its gonna be hard enough turning the bugger with 195/50/16s let alone 215/45/17s.
and 17s on smallish cars can end up looking like a 4wd as well!!!
Post by 340GLT »
Not being funny but shouldnt the profile of 195tyres on 16 inch rims be 45 and down to 40 on the 17's?
Its just i run 195 50 15's and according to a conversion chart on the Toyo website that exactly compares to the overall size of 13" rims? sm14
Cheers Adam
Yes, those numbers look a bit high. I think Al was running 205/35/17s on his GLT to retain the stock diameter. I've been told that wider than 205 with stock diameter = rubbage...but that's unproven. Al needed to do some surgery to avoid rubbing, but I'm not sure if his rims had the correct offset.
cam740
Post by cam740 »
so I should be looking at 195/45/16s guys???
