it would look badassical
project 360
Re: project 360
and vnd after your comment about the primer 300 im quite tempted to paint it in primer with primer wheels at some point
85 360 GLT drift beast
clutch kicks ahoy!!!!
Re: project 360
so i started stripping my spare axle today and i cracked the mythical beat thats is the 300 rear hub lol
i got both of them seperated in well under an hour and with a fair bit of ease
i used the three legged pullers and tightenend them as tight as they would go
then i battered the front of the hub with a large hammer
resulting in epic WIN!!!!!
but i cant swap the brakes for the 360 ones as the drums are bigger meaning ill have to put up with poop 340 handbrake
but ill make up for it with a hydro wand!!!!
but any way thats all for tonight im pooped lol
kev
kev
Re: project 360
i have worked out a way to solve the problem i hope
Re: project 360
well im away to start replacing my wheel bearings today so ill post up lots pics later on
if it all goes well
if it all goes well
Re: project 360
Good luck dude.kds19 wrote:well im away to start replacing my wheel bearings today so ill post up lots pics later on
if it all goes well![]()
Re: project 360 now quite pic heavy!!!
so i started stipping the axle off my 360 to change the wheel bearing housings with new bearings
all went quite well theres a lot of pics so far so ill let them dothe talking
the 340 bearing housings that hold the newer bearings
the 360 away to be stripped of its axle be afraid!!!
lol
sitting amongst a heap of dead cars lol
this bolt started giving me hassle
the easy side done back to the asshole side
my dad got the bolt out with lots of heat and....
... a BLOODY HUGE HAMMER!!!
lol
its off!!!!! wooohhhooooo!!!! thank f*ck time for a cup of tea
so tonight in the wamth of our garage ill be stripping the axle down to replace the bearings and housing
and ill take evan more pics for your viewing pleasure
kev
kev
- trabitom99
Re: project 360
Congrats too for getting the work done in the snow.
Brrr ...
Re: project 360
well i was working away on my axle last night until 4.30 this morning
lol
and had some issues basically one of my nice new motaquip bearings decied to fall apart when i was putting it in!!!
but anyways pics!!!!
separating the 2 parts of hub broke my pullers
(rip draper pullers
lots of shouting, cigrettes and irn bru later and...
woohhhoooo!
the differences 360 hub first
then 340 one
stripped on one side
differences between the bearing housings 340 one on the left i needed to grind the lip flat
like so.
new bearing fitted on one side
one side finished
and the aftermath of my dads garage lol
thats all for just now my dad ordered me a new bearing and is picking it up for me so i should have the car finished today
its alot of work but will be worth it in the end when i get bearings easily
well worth the hassle
but is quite a big job but doable with a big enough hammer and a lot of fags
kev
woohhhoooo!
then 340 one
like so.
one side finished
kev
Re: project 360
ATTENTION!!!!!
be careful of motaquip rear wheels bearings
this is what happened when i was fitting mine
im not saying they are crap im just saying be weary
kev
kev
Re: project 360
yeah lol i sent you a pm.
and yeah i think it must have just been a bad one cos it just disintegrated lol
i've never seen anything like it
- volvodspec
Re: project 360
how did you fit that bearing before it fell apart?
you need a stamp so that the outer ring (wich you try to get into the hub) gets pressed, and NOT the inner ring; pressing the bearing in the wrong way results in a damaged bearing; even if the bearing stays intact
Re: project 360
i used the old bearing on top of it to konck in the new bearing
then when i was done i turned it over and it fell apart
it must hav just been a bad one
