Restoring To Standard 360 GLE
zack360
Post by zack360 »
Thanks Man.
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
01 Volvo S40 Phase 2 Turbo
84 Volvo 240 GL
The steer rack is not so difficult to remove, but the bolts threads need cleaned with a wire brush and penetrating oil. The steering damper rubber can be hard on the knuckles. You will need a ball joint remover. A big hammer on the side can be used, but it may distort the metal, ball joint removers are fairly cheap.
That rust looks pretty bad, it will bad at the seam close to the radius arm, and part of the corner re-enforcement is missing.
viewtopic.php?f=56&t=8733&start=30
zack360
Post by zack360 »
Thanks ride on.. will look for ball joint remover
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
zack360
Post by zack360 »
Hi Mac, I received the parcel today, thank you. I will read it tonight.. Fyi, i've managed to unscrew the top screw that hold the power steering, only left is to unscrew the driver side, mine is RHD.
Zack360
Ball joint remover tool. Have to order.
Received today..
Received today..
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Post by bogbasic »
Excellent work man - I got my 1.7 going again this weekend and it works!! No need to tell us everything about yourself or someone might clone your identity - I'm sure you can trust everyone on this forum but we are open to outsiders 8) Now, Zak, what did you say your date of birth and passport number were ;-?
zack360
Post by zack360 »
Ok got it, maybe a little excited. D.O.B? I'll PM you, as Passport Number I don't have any.
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
zack360
Post by zack360 »
back to work again tomorrow.. almost 2 week delay. Actually there are 2 problem for me now. 1- I cannot open the tyre on Driver side, secondly, I bought the wrong tool.. it's shape like a fork..big size, it says tie rod remover and I don't know how to use it..and a friend said I need to loosen the tie rod end before pulling out the ball joint.
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Post by bogbasic »
No problem Zac, but I now know MAC's real name and I have his paw-mark, too 8) mwahahaha!!
zack360
Post by zack360 »
Hmmm as quote by al pacino in doni brasco "Forget about it"..
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
zack360 wrote: I bought the wrong tool.. it's shape like a fork..big size, it says tie rod remover and I don't know how to use it..and a friend said I need to loosen the tie rod end before pulling out the ball joint.
Slacken the nut, so it doesn't come apart when it pops.
Use bigger hammer.
Those fork things are crap. Use the Volvo tool much better
classicswede wrote:Use the Volvo tool much better
I find a hammer or two works well also. Really depends on the physical access available to the taper joint to be separated.
zack360
Post by zack360 »
Ok.. it will pop..I hope it won't pop on me. I'll post a picture later this evening. Let's see what happen. In the meantime, I checked with local volvo parts supplier in KL, and they have 1 unit brand new power steering rack for volvo 360, and it's a bit costly..RM1760 convert it to GBP would be £323.6. What do you think?
Zack
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
mac
Post by mac »
and I have his paw-mark, too mwahahaha!!
Damn! I was sure I was wearing my "human hand" gloves,
Mabzzzz@#?~rtgoo from planet blarrrrt.
zack360 wrote:What do you think?
Sit it out and play poker with the dealer. It'll still be there in 6 months.
And you still need a pump, heatshield, pipes, brackers, reservior, etc., etc.
