Page 5 of 12
Posted: 05 Jul 2014 12:37 pm
by zack360
Thanks Man.
Posted: 05 Jul 2014 01:16 pm
The steer rack is not so difficult to remove, but the bolts threads need cleaned with a wire brush and penetrating oil. The steering damper rubber can be hard on the knuckles. You will need a ball joint remover. A big hammer on the side can be used, but it may distort the metal, ball joint removers are fairly cheap.
That rust looks pretty bad, it will bad at the seam close to the radius arm, and part of the corner re-enforcement is missing.
viewtopic.php?f=56&t=8733&start=30
Posted: 06 Jul 2014 04:00 pm
by zack360
Thanks ride on.. will look for ball joint remover
Posted: 14 Jul 2014 10:44 am
by zack360
Hi Mac, I received the parcel today, thank you. I will read it tonight.. Fyi, i've managed to unscrew the top screw that hold the power steering, only left is to unscrew the driver side, mine is RHD.
Zack360
Posted: 14 Jul 2014 01:27 pm
by bogbasic
Excellent work man - I got my 1.7 going again this weekend and it works!! No need to tell us everything about yourself or someone might clone your identity - I'm sure you can trust everyone on this forum but we are open to outsiders 8) Now, Zak, what did you say your date of birth and passport number were ;-?
Posted: 14 Jul 2014 08:13 pm
by zack360
Ok got it, maybe a little excited. D.O.B? I'll PM you, as Passport Number I don't have any.
Posted: 14 Jul 2014 08:34 pm
by zack360
back to work again tomorrow.. almost 2 week delay. Actually there are 2 problem for me now. 1- I cannot open the tyre on Driver side, secondly, I bought the wrong tool.. it's shape like a fork..big size, it says tie rod remover and I don't know how to use it..and a friend said I need to loosen the tie rod end before pulling out the ball joint.
Posted: 14 Jul 2014 08:35 pm
by bogbasic
No problem Zac, but I now know MAC's real name and I have his paw-mark, too 8) mwahahaha!!
Posted: 14 Jul 2014 09:37 pm
by zack360
Hmmm as quote by al pacino in doni brasco "Forget about it"..
Posted: 14 Jul 2014 10:38 pm
by macplaxton
zack360 wrote: I bought the wrong tool.. it's shape like a fork..big size, it says tie rod remover and I don't know how to use it..and a friend said I need to loosen the tie rod end before pulling out the ball joint.
Slacken the nut, so it doesn't come apart when it pops.
Use bigger hammer.
Posted: 14 Jul 2014 11:46 pm
Those fork things are crap. Use the Volvo tool much better
Posted: 15 Jul 2014 12:09 am
by macplaxton
classicswede wrote:Use the Volvo tool much better
I find a hammer or two works well also. Really depends on the physical access available to the taper joint to be separated.
Posted: 15 Jul 2014 07:40 am
by zack360
Ok.. it will pop..I hope it won't pop on me. I'll post a picture later this evening. Let's see what happen. In the meantime, I checked with local volvo parts supplier in KL, and they have 1 unit brand new power steering rack for volvo 360, and it's a bit costly..RM1760 convert it to GBP would be £323.6. What do you think?
Zack
Posted: 15 Jul 2014 09:40 am
by mac
and I have his paw-mark, too mwahahaha!!
Damn! I was sure I was wearing my "human hand" gloves,
Mabzzzz@#?~rtgoo from planet blarrrrt.
Posted: 15 Jul 2014 11:36 am
by macplaxton
zack360 wrote:What do you think?
Sit it out and play poker with the dealer. It'll still be there in 6 months.
And you still need a pump, heatshield, pipes, brackers, reservior, etc., etc.
