Half term Fun!!!!
340GLT wrote:
As for the flamer kit it is a big thought at the moment!!!
Imagine at nite headlights and fogs on and a flame out each side!!!
Beast!!
Dead easy to make a flamer kit. Fot extra effect use a little lpg :lol: tis true :D
Omar
Post by Omar »
Here was today in garage has made a photo little bit more largly. (photographed on phone)
Cheers Omar
Crazy about V300 Series
Post by 340GLT »
yeh it will have to be done i think!!!!
Anyways Stage two of the upgrades start in about an hour!!!
Suspension time.
Although i need to change the water pump first as its leaking!!!! :roll:
Anyways speak 2u all 2moro!!!! :wink:
Cheers Adam
Post by 340GLT »
Well i'm back and all i can say is 'Body roll, what body roll?'
Man that thing is awesome now.
I fitted my waterpump and that went quite well despite breaking 4 of the six bolts off in the head, luckily i could get the pump off and get them out with some grips.
Anyway back to the modding, i have fitted my lowering blocks on the rear and only tonight whilst trying to change the anti tramp bar did i find out that its rear mount is slotted. Which gives adjustment and so can be lowered. So it didnt have to be modified!!! Anyway the lower shock mounts have been modded to fit the coilovers and they are brilliant. I put them on the car and am using them purely as dampers for now. They are on setting 4 (of 28 ) and the car is fairly solid 28 would be unthinkable.
The front springs i had were from a 360 GLT and were shorter than the 340 ones and stiffer. However when i was dismantling my sruts i found that one of my springs had broken. Oh dear. This meant i had to go for the GLT springs anyway. But after spending ages putting them on the struts and putting my car back together it mad the front look like it was going to take off, although the front was stiffer. So off they came again and i figured as i have been driving around on a broken spring for so much time cutting the GLT ones down should be ok. So i cut one complete coli off so the end finished level. This resulted in a lowered front and a stiffer spring so job done.
Cheers Adam
These are the only pics i have so far i will ake some beeter ones 2moro!!
Comparison of springs and the 340 one on the right has half a coil broken off too!!!!
Coilover mounted
Ali
Post by Ali »
Very, very interesting stuff there! Looks like a larger than planned drop will be on order once ive got the MOT sorted this week, hmmm now how low can I go with R14/60s :twisted:
Post by 340GLT »
Well pics. Crappy ones at that but there you go. The front looks quite high, but its the same height as it was before and trhe back is lowered 40mm.
Cheers Adam
arnagath
Post by arnagath »
It looks really really good sm71
I hope my project will be ready soon..yaarr..I want this freaking winter to go away!! :evil:
Volvo 340 GL `87 B172K +
Volvo 360 GLT `87 B200E =
Volvo 340 GLT B200E *sold*
Volvo 245 `86 B200K
Omar
Post by Omar »
Yes looks very good. :) Now turning movements you can pass more quickly, with a smaller roll
Ali
Post by Ali »
Looking good mate, any chance of getting the ride height at the rear? I'm in two minds now as to how many coils to chop off the fronts (with my engine being heavier), you not tempted to take another off yours?
Ali
Post by 340GLT »
Would if it would stay in the cup of the strut mate it only just stays in now without i8t falling out!!!. I am tempted to yeh and i might if i can make up some bits to keep the spring in!!!
Cheers Adam
Ali
Post by Ali »
Well at least you wouldn't need spring compressors anymore :P can you let me know if you work out a way of clamping the springs in place because i'll definately be going that route, just a pain that it'll be trial and error cutting them down coil at a time :(
Ali
Post by 340GLT »
Mate when i first put the springs on the car the back was lower with it still jacked up!!!! I cut one spring off andn its fairly low now!!!!
I will try and measure the back for you later.
Actually hasnt Dai got his front springs clamped? I mean Vicky's car???
Cheers Adam
Ali
Post by Ali »
I don't think he has actually I think 300 is the lowest you can go without needing to clamp the springs, im currently at 340mm front and 320mm rear and just been out for a look it looks like the rear can go more as the arch is empty but the front doesnt look like there's much room before it'll scrub the arch lining inside, I can make the blocks in 20mm intervals so don't know whether to make 20mm blocks or 40mm which would basically put the wheel just inside the arch :?
I know what you mean about the standard springs, i've got the glt ones on my 340 and its like a monster truck!
Ali
Post by 340GLT »
Rear ride height is 320mm front is 335mm
Cheers Adam
Vicky's springs are clamped to stop them falling out when the car lifts off the ground. When the new spax are ready there will be no need for clamping as long as the short version works!
