Uprated clutch to fit 1.4 340? (GTT conversion) Info...
- foggyjames
Haha, wow that thing is cute...but I bet it bites
Are the splines/bores wrong or what's the problem with the one which Sachs sells for 300-series?
- foggyjames
Oops! Perhaps some of our resident GTT experts could fill us in on the R5 flywheel size?
The size of the R5 flywheel doesn't matter, that flywheel don't fit. The R5 Clutch don't fit because the splines are different.
This clutch is special for the volvo 1.4...
But, maybe good news... Probebly I CAN use this clutch. I noticed that a clutch from a (ford puma) rallycar has exactly the same "problem", so maybe there is no problem.
- antiekeradio
- foggyjames
I'm not exactly sure why, but those 'paddle' clutches grip harder than standard discs. Perhaps it's a way of balancing out the effects of a much grippier friction material. Must say it's an area I'm not at all hot on.
I realise that you can't use a GTT flywheel Fritz, but I thought perhaps that might explain how it came to be that size - if the friction area had been specced for a GTT (with perhaps a smaller flywheel?), and just the splines changed to suit a 340?
we've a couple of paddle clutches for the 360. i think the compound material is much "grippier" and they get rid of the heat better. they look a bit like the 1 above but are much more like 4 seperate paddles...a X kind of shape. if it wasnt -4 outside i may goto the outhouse and get a photo of the spare......
They are like a switch. A freind of mine has one on his mini - that is exactly what it is like. There is no chance of holding the car on the clutch. Also the pedal is harder to press.
hi!
thats a sweeeet paddle clutch! where is it from? sachs? or is it bespoke?
Ive got a friend with a 2.1 240 turbo ( cosworth turbo ) putting out 500bhp... its that paddle clutch the reminded me of his car. he has a paddle clutch as it is rather like a switch. James, Ive also puzzled how those paddle clutches work... less contact area but a greater ability to tranmit torque and less slip on engagement.... eh?? but they DO work!
I'll try to contact the mad 240 owner... get some more info for you all. the engine was a bespoke rebuilt 2.1. It would spin its wheels in 5th!! orig gearbox I recall but lsd unit from quaife.
all the best
S
all the best
S
Enjoy your 300s
- foggyjames
I would be interested to hear the spec on that car Shimon!
