and beside that you can quite easaly convert rhd headlights to lhd
Volvo 350R T5 Engine Track Project U/D 18/02/13
- volvodspec
Re: Volvo 340R EVO 3 Update 07/08/09 Coilovers!!!
offcourse!, but shiny housings look cool:D
vØlvØfreak
The reflectors are different, due to the fact of RHD and LHD. How could that be changed easily?volvodspec wrote: and beside that you can quite easaly convert rhd headlights to lhd
The glass has a different pattern for the beam.
The reflectors are also DEFINITELY different, I ended up with a LHD one when I bought some new ones to refurb a set
- foggyjames
You know you've been neglecting V3M when you find a months-old thread of epic proportions has passed you by...
Awesome work, as always, bud. In for the updates...
- 340GLT
I told you to look at my thread!!!
hahaha
hahaha
- foggyjames
You did indeed...and I have missed a lot!
awsome fab work on the axel! realy like the car too
'87 Volvo 340 'valver
- 340GLT
Part nos as follows....... Not much progress, got my 360 transaxle setup out of the saloon to start mocking up.
- volvodspec
- 340GLT
Re: Volvo 340R EVO 3 Update 23/09/09 4 Pots
Due toweather and other commitments work has been slow on the grey car up until now where it should speed up a fair bit.
Been working on my front brakes the last couple of days.
sorry for asking the brake clipers are from what ?
- 340GLT
Mazda Rx7 FD3
- 340GLT
Well due to other commitments etc time recently on this car has been getting thin. Although i have been having some components made in the background, so i picked them up earlier and spent a bit of time on the car.
Firstly i fitted the longer studs to the front hubs which is dead easy, more of a pain on the back!! The studs are around 30mm longer.
Drilled hubs out to 14mm to accept the impreza studs. Then used a flanged nut and a steel spacer to wind the studs in.
Next i picked up my suspension components!!
The problem with sitting a 300 on its arse on the front with standard rolling diameter wheels is that it ends up being sat on its bump stops with no travel, so my solution is as follows!!!! Test fit tommorow.
