Duchess The Volvo 340 CVT
mac
Re: Duchess The Volvo 340 CVT
Post by mac »
Afternoon girls,
Just to add to the handbrake stops - currently second version is under test by Mac and Volvomania (Born Built Beauties).
Initial thoughts are that they are first class - they seem very strong, layer resolution seems to be <0.1mm and no separation even under considerable force.
All credit to Ben for his work in producing the 3D printing program and arranging for manufacture.
Assuming they pass muster - which seems likely they will be available from Mac, BBB, and probably Ben as well. Final price point has not yet been determined but will be around £2.50 - £3.00 each.
Mac.
Post by trabitom99 »
That's great news. Well done, Ben and Mac ...
benji1985
Post by benji1985 »
Good day everyone.
The last couple days have been productive
15/04/16
My hubs were picked up from the machine shop, the stud holes have been drilled out to 14mm, the new studs pulled in really easy and look good.
ImageIMAG4048 by Benjamin Charlton, on Flickr
And the spare fuel tank was cleaned up ready for painting.
ImageIMAG4049 by Benjamin Charlton, on Flickr
The metal tube that supplies the vacuum to the CVT unit needed to be welded back to the bracket. Then painted up, came out quite well.
ImageIMAG4050 by Benjamin Charlton, on Flickr
16/04/16
Today the cleaned parts got painted with POR15
The anti roll bar.
ImageIMAG4055 by Benjamin Charlton, on Flickr
The rear hubs.
ImageIMAG4052 by Benjamin Charlton, on Flickr
The front hubs.
ImageIMAG4051 by Benjamin Charlton, on Flickr
The CVT unit mounting frame.
ImageIMAG4054 by Benjamin Charlton, on Flickr
The leaf springs
ImageIMAG4053 by Benjamin Charlton, on Flickr
The fuel tank, this came up so well
ImageIMAG4056 by Benjamin Charlton, on Flickr
ImageIMAG4057 by Benjamin Charlton, on Flickr
Some more work on the car tomorrow while it is sunny.
Little up update on the hand brake stops, there are on my rear axle and the work well :)
ImageIMAG4059 by Benjamin Charlton, on Flickr
ImageIMAG4058 by Benjamin Charlton, on Flickr
Watch this space for more updated
Ben
Post by bogbasic »
Epic work, an awesome project.
benji1985
Post by benji1985 »
bogbasic wrote:Epic work, an awesome project.
Thank you :D
thododd
Post by thododd »
Lovely stuff.
I put my POR'd axle back together this week and after accidentally sliding the knurled end of my ratchet across it and not making a mark i started throwing spanners at it for fun :D
360beast
Post by 360beast »
thododd wrote:Lovely stuff.
I can genuinely picture you doing that Tom! :lol:
benji1985
Post by benji1985 »
Hello all, updates for you all, some good some not so good :?
17/04/16
My plan started today to underseal the back section of the car, which meant removing all the remaining bits, this started with the fuel lines, so undid them from the fuel pump and then discovered that one of the pipes was split (maybe why her MPG was quite bad...)
ImageIMAG4064 by Benjamin Charlton, on Flickr
The next line was the big long brake pipe, to do this the pipe had to be removed from the "equalizer" (I think that is what it is called), however to gain a good access the heater box had to be removed, so the box was opened up to find the heater resister wired like this:
ImageIMAG4065 by Benjamin Charlton, on Flickr
also the foam had completely disintegrated.
ImageIMAG4068 by Benjamin Charlton, on Flickr
Then CVT declutching servo had to be removed (again I think that is what it is called)
ImageIMAG4067 by Benjamin Charlton, on Flickr
at last i could get to the brake lines,
ImageIMAG4069 by Benjamin Charlton, on Flickr
I un-clipped the fuel lines and brake line from under the car and with drew them, next was the vac line to the CVT units, these would not move at all, turns out that they had glued themselves in in the chassis, long flat bar managed to un stick them and out they came too. by this point I spent a good lump of the day removing bits and thought I should put the undersealing off till the next day (as you can guess I hate doing undersealing)
removed that remaining brackets and the fuel tank filler hose, now she is ready to be undersealed once she has been wire brushed.
ImageIMAG4073 by Benjamin Charlton, on Flickr
(you can see the previous attempts by me to underseal)
ImageIMAG4074 by Benjamin Charlton, on Flickr
ImageIMAG4076 by Benjamin Charlton, on Flickr
ImageIMAG4075 by Benjamin Charlton, on Flickr
ImageIMAG4077 by Benjamin Charlton, on Flickr
ImageIMAG4078 by Benjamin Charlton, on Flickr
Few dents in the chassis, been there for as long as i can remember.
I then realised that the rear bumper was mounted in the area that would have underseal on, so set about removing that, as expected all 4 bolts broke, New ones to be sourced, thank you Mac.
So after removing the bumper I found this!
ImageIMAG4079 by Benjamin Charlton, on Flickr
ImageIMAG4080 by Benjamin Charlton, on Flickr
more to come on this hole....
I removed the radiator too as this day shaped up to be a removing of things day
ImageIMAG4081 by Benjamin Charlton, on Flickr
Rear mud flaps removed
ImageIMAG4082 by Benjamin Charlton, on Flickr
Grill and associated bits
ImageIMAG4083 by Benjamin Charlton, on Flickr
Heater box
ImageIMAG4086 by Benjamin Charlton, on Flickr
No idea what this is called... going with "Brace bar"
ImageIMAG4087 by Benjamin Charlton, on Flickr
CVT de-clutching servo?
ImageIMAG4088 by Benjamin Charlton, on Flickr
Brake equaliser
ImageIMAG4089 by Benjamin Charlton, on Flickr
Master cylinder removed a little while ago
ImageIMAG4090 by Benjamin Charlton, on Flickr
Renix unit
ImageIMAG4091 by Benjamin Charlton, on Flickr
Spare wheel support bar
ImageIMAG4092 by Benjamin Charlton, on Flickr
Fuel lines
ImageIMAG4093 by Benjamin Charlton, on Flickr
Vac lines
ImageIMAG4094 by Benjamin Charlton, on Flickr
Brake lines, couple of the small ones need to be re-made
ImageIMAG4095 by Benjamin Charlton, on Flickr
While all this was going on, the top coat of POR15 was drying on some of the parts
ImageIMAG4096 by Benjamin Charlton, on Flickr
ImageIMAG4097 by Benjamin Charlton, on Flickr
ImageIMAG4098 by Benjamin Charlton, on Flickr
ImageIMAG4099 by Benjamin Charlton, on Flickr
few little runs in the paint :(
ImageIMAG4100 by Benjamin Charlton, on Flickr
Heater box internals
ImageIMAG4101 by Benjamin Charlton, on Flickr
18/04/16
Today i was going to crack on with the undersealing..... this didn't happen, i thought to myself that I should probably put some anti-rust stuff on first before the underseal, Mac confirmed that this should happen, so again the underseal was postponed.
However had a good look around the engine bay as all that is left is the engine and steering rack, and found some more rust :(
These are in the corners above the fuse box and wiper moter and under the rubber seal
ImageIMAG4107 by Benjamin Charlton, on Flickr
ImageIMAG4108 by Benjamin Charlton, on Flickr
ImageIMAG4109 by Benjamin Charlton, on Flickr
ImageIMAG4110 by Benjamin Charlton, on Flickr (fuse box side)
ImageIMAG4111 by Benjamin Charlton, on Flickr (fuse box side)
ImageIMAG4112 by Benjamin Charlton, on Flickr (could just be surface rust.... hoping (it wasn't.....))
now for the rust under the rear bumper, a little poke and prod later...
ImageIMAG4113 by Benjamin Charlton, on Flickr
It has gone through to the rear lights, So i have duct taped it up for now just to try and help a little.
Oh yes and the bad bit (sorry no photos, I was in a very bad mood at this point), I was trying to losen the bolts that hold the engine beam in, ready to take them off once the engine was removed, applied heat and penetrating oil, but no the little bugger (a lot more civil words than what was used) snapped in the chassis...... By this point i gave up for the day and phoned Mac and have come up with a plan of action.
I have just brought a new welder, still need to get the gas and bits have all the PPE.
So my question thus far are:
1) the foam that fell apart in the heater box, where can i get new stuff and what am i looking for?
2) the broken bolt in the chassis is held in via a tube thing welded on the inside of the chassis does anyone know the diameter of this tube that the bolts go in to are?
Ben
Post by bogbasic »
Hello again and sorry to hear about the problems you had. I can only help with cosmetics here - the heater air filter can be replaced with dust filter material which you can buy for workshop tools on the bay. I replaced two of mine with such material and it seems fine. I got rectangular bands of it which I stretched over the plastic support. Not brilliant but OK and I think you can see the results in my blog towards the end of last year....
You are doing a brilliant job here chap, the rust was bound to pop up at some point though. I've had one of those engine beam bolts snap on pretty much every one I've removed, each time I've added more penetrating oil for more days before hand and heated it up, still always gone.
benji1985
Post by benji1985 »
bogbasic wrote:Hello again and sorry to hear about the problems you had. I can only help with cosmetics here - the heater air filter can be replaced with dust filter material which you can buy for workshop tools on the bay. I replaced two of mine with such material and it seems fine. I got rectangular bands of it which I stretched over the plastic support. Not brilliant but OK and I think you can see the results in my blog towards the end of last year....
Ah didn't think of that for a foam replacment...
benji1985
Post by benji1985 »
Chris_C wrote:You are doing a brilliant job here chap, the rust was bound to pop up at some point though. I've had one of those engine beam bolts snap on pretty much every one I've removed, each time I've added more penetrating oil for more days before hand and heated it up, still always gone.
Thank you, I have just brought myself a welder and have a plan to convert the inserts to studs, just hope I have the welding skills to do it :)
Ben
benji1985
Post by benji1985 »
I do enjoy reading through your website, keeps my hopes up :)
Ben
Post by MCHUDD »
There is not half a bit of work going on here. Brilliant.
sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4
benji1985
Post by benji1985 »
MCHUDD wrote:Hi mate.
Thank you :D
