Ride_on I have had a change of planand I am planning to do this over the two weeks I am off work (shortly). I will move my Nissan project to my mates rented garage, but not before we rehouse his mk1 XR2 in Hereford and the 940 temporarily shacks up there whilst I remove its heart lol. So I will have the 360 at home when the work commences, in the dry and relative space. Enough to drop the tank etc etc.
Dropping the tank won't be so bad then if I'm not doing it outside etc lol. I've had most of the required parts off before to weld the diff up. I also had to replace the downpipe a couple of months back after I caught the centre box one too many times and it snapped the DP I know my way around that area now, but I'm not saying it's not a cnut of a job still!
There's gonna be nothing left of the car as I need to replace the leaves and change the front shocks/springs etc. Maybe make larger blocks too. Meh, may as well do it in a oner.
Interesting info on the fuel pump situ. I guess that isn't the end of the world though.
Maybe my flywheel search is about to end also...
Steve Cheers mate. I'll bear that in mind. How much would you be after for them? I think I may use the block, but the pump you have could be useful. Unsure as of yet! Good old Frontera IC's eh. They fit ebverything lol. I hadn't considered them tbh. Was thinking of eBay alloy jobs.
Pyro Sounds ideal mate. From what I can gather if I want to run standard management then I 100% need a flat fly, yeah? Also is this one compatible with the 360 clutch plate?
I know the info is probably already in this thread, but there's a lot to polugh through. So this is the easiest way.
How much are you after dude?
I would normally use the search more, but It's pretty crap for this purpose tbh!
Cheers gents, keep it comin!
