360 GLE Carb
clitti
Post by clitti »
I managed to fit a twin 40 down draft on my 360 GLS.It came off of a ford 2.8 i think.It was an upgrade of sorts just so i did not have to put the loom and ecu and other stuff on the GLS.It had a kent cam L4 profile on the engine and was useless under 3000 rpm but once it got there it went like the clappers.I used a piece of 10mm aluminium to make an adapter and fabricated a throttle cable holder.The only thing i did not have time for was to get the carb jetted and set up for the engine it went on,and the result being we ran out of petrol about 6 miles from the end of the rally.I knew it had to be tuned as the smell coming out the exhaust was so rich you could not drive behind the car with your windows down as i made your eyes water.I was at a red light one day and a van pulled up behind me and you should have seen the bloke, he could'nt wind his window up quick enough.LOL.
http://i170.photobucket.com/albums/u265 ... C00222.jpg
http://i170.photobucket.com/albums/u265 ... C00221.jpg
http://i170.photobucket.com/albums/u265 ... C00220.jpg
http://i170.photobucket.com/albums/u265 ... C00219.jpg
Gad i ganu.....?
Jason B
Post by Jason B »
lol, funnily enough I do still have a 38dgas here on the shelf, trouble is I think it'll be a lot harder (and more expensive) to setup the engine with that than to use an lh2.4 injection setup. How would you choose to control ignition on a 2.3l if you ditched the injection setup?
clitti
Post by clitti »
Use a 240 electronic dizzy,the one with the hall sensor in the dizzy and the amplifier pack.It has always worked for me in the past.
A couple of pictures for ID purposes.
http://i170.photobucket.com/albums/u265 ... C00225.jpg
http://i170.photobucket.com/albums/u265 ... C00224.jpg
Gad i ganu.....?
Jason B
Post by Jason B »
straightforward I suppose, trouble is I don't reckon that carbs are worth doing power to pound wise as lh2.4 will just adapt to on its own to any mods whereas carbs would need retuning
clitti
Post by clitti »
My thoughts exactly.But i am goin to stick with the L Jetronic and the 240 dizzy coz its reliable as hell.The other advantage of using the 240 ignition setup is that you can get rid of the huge flywheel and go for the early 240 flat flywheel.It makes quite a difference.
Gad i ganu.....?
Jason B
Post by Jason B »
good point, I have been considering getting a new lightened steel flywheel designed for lh2.4 that was apparently very close to fruition, not sure yet though
Jason B
Post by Jason B »
Right, started sorting through the bits to fit to the car! - had time in the evenings and some days when not working to play with some suspension, as the car is for rally use I havent been to bothered about making things look too nice (they will get very muddy again soon :D), just cleaning them up and renewing/painting as required. Fitted a couple bits and pieces including dai's wishbone bushes and some superflex radius arm ones as well as the main event ;):
