after purchasing my second 300 i have to admit ive caught the bug with these cool little cars.
im looking for some advice on swapping the engine in my f reg 340 1.4 dl with something a bit more interesteing. in this case an ebay purchased 1.8 f7p.
i know the topic has been covered manytimes before, but i need some advice.
i have done a search on the forum and tried to research as much as possible, im just in need of some advice to check i have got everything right before taking my car off the road to commence the conversion.
so i understand that to put the engine in my car i need some parts from the 1.7 340,
as far as i can tell these are:
bell housing
engine mounts
sump
clutch cable
clutch
rad hoses, is there an aftermarket option available for these?
alternator mounts
1.7 rad
what do i need from the f7p?
obviously the engine and loom? ecu.
flywheel
exhaust downpipe? although this isnt such an issue as i plan to have a system fabricated.
i know you need to flip the intake on the inlet but this wouldnt be an issue as i plan to run the engine on bike carbs, with a custom manifold, what would i need to change fueling wise? or would the 1.4 fuel pump be sufice?
also where would this leave me with the existing loom/injection system.
and finaly on the setup, can i run the exisiting ignition system? if not what ecu/dizzy/setup do i require.
any help would be greatly appreiciated,
