I dont have anyway of measuring the thread etc of the studs on my 340, does anyone know the specs of the top of thier head?
Need to order longer ones for my spacers
also are they press fitted or threaded in
Ant
wheel stud specifications
- 340GLT
Re: wheel stud specifications
They re 12x1.25, if you buy extended subaru impreza ones, drill the hub out to 14mm and refit them. They are pressed in, but you can wind them in with a machined spacer and a nut.
I run impreza ones on mine.
do i have to use subaru ones or can i just hi jack deom tweeks for whatever they have?
- 2 Fast 4 U
No they are M12 x 1.50340GLT wrote:They re 12x1.25,
mine are 1.25 like.2 Fast 4 U wrote:No they are M12 x 1.50340GLT wrote:They re 12x1.25,
- 2 Fast 4 U
I just measured them and they are indeed M12 x 1.25 sorry
so I have bought extended subaru ones, do i just need a 14mm drill bit drill the hubs then bash em in with a hammer and a bit of heat and lock tight?
- volvodspec
yep, apart from beating them in with a hammer...
just use a spacer and a nut to get them in
so i effectively pull them through using the nut against the spacer?
- volvodspec
