2.0 F7R spark problem
Donut
Post by Donut »
Hi, I'm fitting an f7r engine in my 1987 340 gl. I've fitted the engine, loom and ecu, new fuel system, and ignition system. Amongst many other little things. I have a problem at the coil, there's power going in but there's nothing coming out. It's a brand new coil pack for a Clio Williams, it has two plugs, one from Volvo loom and one from Clio loom. Leads and plugs are new also. I'm confused? :340:
Re: 2.0 F7R spark problem
You have tried replacing the coil so far haven't you?
Post by 340GLT »
What exactly do you have from which loom? Power on the 3 pin plug from volvo loom and two pin plug with single wire in it from renault?
What flywheel are you using?
Donut
Post by Donut »
The coil and module are brand spanking new. Will try another but I only have a 1.8 coil. The wires are as you say, adz, three pin connector from Volvo and one single wire from Renault loom in a two pin connector. I think I'm using the 1.7 flywheel I'm not 100%. How can tell the difference?
Post by 340GLT »
Where has the loom and engine come from?? And your running a Renault crank sensor??
Donut
Post by Donut »
Yeah I'm using the crank sensor from the Renault loom. I got the engine from Nev, ring any bells?
Donut
Post by Donut »
The engine is from a williams Clio mk1 I believe.
Donut
Post by Donut »
The loom and engine were previously fitted in a Volvo. So the loom has been cut about to loose unnessasarry wires. I didn't hear it running but was assured it all works fine. I bought it from a local garage who is a trusted friend of a friend.
Post by 340GLT »
What are the last 3 digits of the S101 no on the ECU?
Donut
Post by Donut »
The last three digits on the ecu are 107.
Post by 340GLT »
Genuine williams ECU then. Can you take pictures of various elements of the installation. I'm almost putting this down to a loom problem.
What exactly are the symptoms?
Donut
Post by Donut »
I've got hundreds of photos but because I use my phone for most of my Internet I'm having trouble loading pics. Where do post pics? Here? I've tried using the renix coil and the same probs occur. No output. I've chased the wires to and from the ecu, two in from crank and one out to coil, all have continuity and the crank sensor works fine when placed over an earth. I did notice last night I had left the capacitor off the coil, however, no improvement. Grrrr. Thank you, Adam
