BBK, Coilover kit, MS, LH2.4 tuning kit, Wideband, Camshaft
Bossie
Post by Bossie »
Coilover kit:
New Koni Classis (short strut insert)+ rally design coilover kit. Everything is new, never been used.
Koni cost me E140, Rallydesign parts were E100 excl shipping. Will let it gor for E200+ shipping which is a steal.
Can include some Nissan adjustable top mounts if you like, also new, E65 (which again is a steel)
Big brake kit:
Disks are the 280x22mm VWG60 disks. Just replacement parts from ebay. Payed E70.
Calipers are alloy 4pot RX7 calipers. Payed E150.
The hubs are included if you like, you only pay the additional shipping.
Price for everything, E170
If you buy both the coilover kit+brakes I will give a discount. Instead of E370 I'll take E340 for both of them, incl the camber plates/solid topmounts E385 (excl ship)
Flexi Tune:
Convert to E85 or just richen up the mixture on petrol.
MS1 PCB3
Came from a running B234+T.
Includes wiring loom (everything has been labeled), sensors, wasted spark pack (bosch motorsport) and some other bits and pieces.
Price: E350
Can include a LH2.4 60-2 dog dish fleewheel if you need one for E25+ additional shipping:
MLS Gasket, thinnest available multi layer steel headgasket avaible for B23/230. Will raise the crwith .5, increased torque, tight squish and economy: E100
Volvo K camshaft (no distributor drive): E75
Volvo 1000 405 head (like 531). Better flowing Volvo 8v head. Came from a strong running k-jet car, small coolant ports: E125
Jaw Wideband: E100 (includes a new wideband sensor as well)
LH2.4 tuning chips, some leftovers:
1 set of turbobricks B230FT/FK turbo chips, with raised rev limiter(6800rpm) E100
1 set of turbobricks B230F/FB N/A chips, rev limiter at 7500rpm (works nice with a K-cam) E100
1 set of Hi-Tuning B230FT/FK chips: E50
1 Viking eco max chip for your B230FT/FK ecu (just fuel) E75
1 set of custom chips for a modded B230FT/FK (cam, bigger exhaust, better turbo: E150
Complete LH2.4 tuning package:
Ostrich emulator from moates worth E150
JAW wideband worth E100
Both the ostrich and the JAW work with other cars and EMS as well!!!
Several chips (worth E475, like posted above)
As a package deal: E300
Package of exhaust parts, all new, all 2.5". Everything to build yourself a 2.5"exhaust system should be there.
2 90 degree bends
1 over the axle bend
1 straight length of 2.5" pipe, will check how long exactly
All new! E75
Might even be able to include a new simons 2.5"silencer, will have a look. Quite a big silencer, if I can find it: E60
Feel free to contact me with any questions.
Vermilion
Re: BBK, Coilover kit, MS, LH2.4 tuning kit, Wideband, Camsh
Post by Vermilion »
Are the callipers&discs a direct fit?
Volvo 340 L 1983
ross_striker
Post by ross_striker »
Yeah same as above, come with hangers?
Bossie
Post by Bossie »
You have to use the adapter brackets 340GLT/Adam makes/sells.
Hubs have a different boltpattern, so disks need redrilling. Most of this is all covered in 340GLT's project thread since it's basically the same upgrade as his.
Vermilion
Post by Vermilion »
You're going to VKB or any other v3c meeting?
(waarom post ik dit eigenlijk allemaal in het engels)
Volvo 340 L 1983
Ik heb deze zin in een vertaler en het kwam uit in het Nederlands! (Denk ik)
Vermilion
Post by Vermilion »
Yes, it's dutch :D sm1
Volvo 340 L 1983
parklife87
Post by parklife87 »
How much to ship coilovers to UK?
