What is the 1.7 correct idle speed?
MOT today, failed on high idle. Fair enough I said, what should it be? The man said it should be whatever the documents on the 340 say it should be, regardless of what engine is in it now. I'm a tiny bit worried though because I can't get the F7R to idle less than 1k. It sits fine at about 1000/1100 though. My mind says it should pass with this but I'm not exactly sure what the correct idle on the 1.7 is? Anyone know?
- volvodspec
Re: What is the 1.7 correct idle speed?
correct idle rpm for B172 is 900 +/- 50rpm
Blimey so how high was it for them to fail it? I've never heard of that before.
1.5 to 2k, alternating. It threw a wobbly on the morning of the test
Still flew through emissions though, it's now fixed.
The arsey garage failed Fake once for high idle, so I asked them to show me as I knew it was fine. Turned out the f*ckwit didn't realise the choke had to be pushed in as well as out, or he was trying to pull a fast one. Put me off the garage though.
Speedy, come round at some point and we'll see what we can do for yours if it's still being a pain, it took me ages to get my idle sorted to a rock solid 950
Cheers, will do, its not an idle problem as such that I have now but it will sometimes stall coming up to stop. Still going to have a play with the mixture screw and see if it's that
lol no wonder, you'd have got away with 1000-1100 I reckon but 1.5-2k is waaaay high
