Diffrence between 1.4 cvt and manual?
Posted: 17 Oct 2010 10:38 pm
by Gordon F
Quick question. has anyone fitted a cvt engine to a manual? its a 1989 b14.4e thats in the car just now was just wondering if its a simple case of swap the flywheel/clutch over or if theres more parts required. Cheers.
Re: Diffrence between 1.4 cvt and manual?
Posted: 17 Oct 2010 11:05 pm
by volvosneverdie
Engine is the same engine dude. Only the drivetrains differ.
It's a lot of work to convert from rubberbelts to a traditional manual gearbox, but possible.
Hth.
Posted: 17 Oct 2010 11:10 pm
by Gordon F
the car i have just now is manual so all the parts are there?does this mean i justneed to put my clutch, flywheel and bellhousing on? cheers
Posted: 17 Oct 2010 11:14 pm
by volvosneverdie
Ah I see what you mean. You're putting a b14 from a cvt into your manual car. Sorry, I mis understood your question.
I think so. But an expertll know for sure. Sure onell bevalong in a minute.
Posted: 18 Oct 2010 10:02 am
by Gordon F
yeah loo
Posted: 18 Oct 2010 11:01 am
by Speedy88
Seeing as nobody has said anything yet, I'm gonna say that you should only need to swap the flywheel/clutch on the engine. There are some vacuum hoses that will be left redundant which is the bit I'm not sure about, I don't want to just say to blank them off...
Posted: 18 Oct 2010 01:42 pm
by macplaxton
(Engine from 1.4CVT going into a 1.4 manual car.)
The only things I can see in the green books is that the flywheel and everything behind has to come off the AT (auto transmission) engine and the manual equivalents put on. The other thing mentioned in the manual is the front engine mountings have some thick washers on the MT (manual transmission) engines.
Other than that I don't foresee any problems.
What I would do is to do a compression check on the engine. Then I'd plonk it in. I'd adjust the valve clearances while I'm at it and compare the carb specs / inlet manifold closely. There may or may not be an extra vacuum take off on the carb or manifold baseplate to assist functioning of the AT, but I've never looked at them back-to-back, so I could be talking cobblers here
Filthyjohn might know something as he converted a 1.4CVT car
to manual, which is somewhat a bit more involved than plonking an engine from a AT car into a MT.
(thread HERE)
Where's Anjo when you need him?
Posted: 18 Oct 2010 03:31 pm
by Gordon F
would have though someone out there would have done this ! lol may just give it a bash myself and see how it goes?
Posted: 18 Oct 2010 04:18 pm
by volvodspec
macplaxton wrote:Where's Anjo when you need him?
aye aye captain!
macplaxton wrote:The only things I can see in the green books is that the flywheel and everything behind has to come off the AT (auto transmission) engine and the manual equivalents put on. The other thing mentioned in the manual is the front engine mountings have some thick washers on the MT (manual transmission) engines.
the washers are only on the 340 MT's before MY85 wich have the upright engine mounts, last 300 wich had this is chassisno 910265. with intruduction of the D16 all 340's got the engine mounts on an angle and the washers weren't needed anymore.
Gordon F wrote:would have thought someone out there would have done this ! lol may just give it a bash myself and see how it goes?
more times than i would've wanted too actually
may i ask if the CVT and MT engines have the same engine code (B14.4E?? or something else), you can find the badge just above the oil filter.
parts to swap:
- flywheel
- clutch
- complete bellhousing + bolts.
the flywheel guard plate wich bolts to the bellhousing can be kept, you can also reuse the flywheelbolts, clean the threads with a wire brush before you insert them, the flywheel itself will bolt straight on but there's only one way to fit it.
if the CVT clutchplate looks good with all the cooling slots still present, you may want to sell the complete package to a CVT enthousiast, as new clutches are rather expensive.
Posted: 18 Oct 2010 05:11 pm
by macplaxton
volvodspec wrote:if the CVT clutchplate looks good with all the cooling slots still present, you may want to sell the complete package to a CVT enthousiast, as new clutches are rather expensive.
I was hoping of the return of those items given the bargain basement price I'm letting this go for!
Posted: 18 Oct 2010 05:17 pm
by Gordon F
my current engine is the b14.4e would you be able to find out the code from yours mac? Cheers for the replies.
Posted: 22 Oct 2010 03:00 pm
by Gordon F
volvodspec wrote:macplaxton wrote:Where's Anjo when you need him?
aye aye captain!
parts to swap:
- flywheel
- clutch
got the engine in an running no probs exactly as volvodspec had described
cheers for the replies and cheers macplaxton for the engine
Posted: 22 Oct 2010 03:17 pm
by volvosneverdie
Result!
Got to love good news.
by volvosneverdie
Result!
Posted: 22 Oct 2010 11:43 pm
by macplaxton
Bloody hell, that was quick! (says Mr Tardy
Good to hear you're back in the game.
