how are the front springs held in?
Posted: 28 Oct 2010 10:14 pm
by samueljon
how are the front springs held into place?
there is the bottom plate whats at the top holding them as what ever it is looks pretty f*cked on mine the spring can move so i take it that means its screwed?
Re: how are the front springs held in?
Posted: 29 Oct 2010 03:36 am
The bolt on top of the shock holds the top spring plate along with the top bush and bearing. The bolt surface is normally held on with 3 or 4 spot welds to the bigger spring plate, but its probably rusted through or badly split and cracked. So you will need a replacement, NLA from Volvo, so its a recovered part or complete redesign. I think Dia (Classicswede) might do a conversion, but probably pricey.
Posted: 29 Oct 2010 08:52 am
by samueljon
Just stuck an order in with him for the set new front and rear shocks with springs.
will see what they include when they get here.
Posted: 30 Oct 2010 02:58 pm
Obviously I don't know what you have ordered, but shocks and springs for a 300 normally mean just that, The shocks are inserts and the top spring plate would not be included unless you ordered complete struts.
Posted: 01 Nov 2010 10:11 am
by samueljon
ok
i have ordered springs, front and rear shocks....
so i will still need to find the "pan"
does anyone know anywhere i can get the top spring pan ill be taking the wheel off tonight to have a proper look but i think its rusted through and the spring has mooshed it
any help would be appreciated
Sam
