roll cage for volvo 360 glt 5 door
roadrallyliam
Post by roadrallyliam »
does anyone know where i can get a roll cage for a 360 5 door?
Re: roll cage for volvo 360 glt 5 door
yep.
Pm madseb.
roadrallyliam
you wouldnt know any one that i could get some sump guards off?
magnumpi
Post by magnumpi »
roadrallyliam wrote:you wouldnt know any one that i could get some sump guards off?
Rally Sport, Demon Tweekers etc, i don't think anyone does a 300 specific sump guard.
Pretty easy to make one with some chequer plate a hammer and a bit of your time :D
Alex Laidlaw
Post by Alex Laidlaw »
I made a quick botch sump guard mounting using an exhaust bracket around the tubular front member and putting some M8 bolts through the cross member where the plastic splash guard usually bolts to. Although not ideal it has taken a fair bit of abuse the only real snag being that the nuts on the exhaust bracket aren't countersunk so I replace the exhaust bracket every time I take the sump guard off.
roadrallyliam
Alex Laidlaw wrote:I made a quick botch sump guard mounting using an exhaust bracket around the tubular front member and putting some M8 bolts through the cross member where the plastic splash guard usually bolts to. Although not ideal it has taken a fair bit of abuse the only real snag being that the nuts on the exhaust bracket aren't countersunk so I replace the exhaust bracket every time I take the sump guard off.
ive just been getting a 360 and im looking to road rally from jan on wards. would you be able to take sum picture so i could get a ruff idea off wat i need to make?
Nimminz
Post by Nimminz »
