Confused...
Confused...
Post by Tom »
Starter motor packed in today while in the McDonalds car park..so I called the breakdown cover people and they sent a bloke in a recovery truck who aided me to bump start it. After driving it home, I left it in the drive for a while and then went back to try and start it. Starter motor turned as normal (seemingly) although the engine didn't fire till after a few attempts. After that started on the button at each attempt.
Should I take it to a garage or just carry on?
F983 OHD '88 340DL - Gone but not forgotten
C299 LGF '86 340DL - Variomatic jerkiness
Might well be a dodgy connection. Engine earth and starter solenoid connections are always a favourite.
Solaniod stickings another good one... though the breakdown guys usually hit them with a hammer, and the starter wouldn't turn at all if the solaniod is stuck (think of it as a huge relay)
5lab
Post by 5lab »
if it goes again, simply get a big spanner out and give it a thump. once starters are on their way out they tend to work intermittently
Bilbo
Post by Bilbo »
the pinion can get stuck in ring gear causing it to just click when trying! only way to get it to recoil apart from stripping ,is to bump start it .
this has happened to me many times in many cars.
