samueljon
Posts: 341 Joined: 30 Jun 2010 02:07 pm
Post
by samueljon » 06 Dec 2010 10:25 pm
4 speed gear box to a 5 speed gear box...
straight swap??
its bolting onto a f7r (1.
Posts: 1921 Joined: 06 Dec 2008 09:35 pm
Post
by volvodspec » 06 Dec 2010 10:31 pm
jup straight swap if the 5spd is from a 340
360 gearbox requires a bit more work to convert to 340 fitment...
samueljon
Post
by samueljon » 06 Dec 2010 10:44 pm
na ill be finding a 340 gear box save the messing about
Posts: 2266 Joined: 26 May 2009 05:34 pm
Post
by Ride_on » 07 Dec 2010 03:01 pm
I assume you are getting the diff aswell with the gearbox. 5 speeds diffs are a different length to 4 speeds ones.
Posts: 9600 Joined: 18 Jun 2004 11:53 pm
Post
by Chris_C » 07 Dec 2010 03:56 pm
Ride_on wrote: I assume you are getting the diff aswell with the gearbox. 5 speeds diffs are a different length to 4 speeds ones.
Really? Propshafts certainly are, I've never noticed a difference on the diff. It is easier to swap the box and diff as a single unit anyway.
Post
by volvodspec » 07 Dec 2010 08:12 pm
4 and 5speed propshafts are the same, the only variety is between CVT and manual.
gearbox + diff have the same overall length is you compare a 4 speed to a 5speed,
the difference is that behind the gearbox's 1,2,3,4+R section the 5th gear unit is placed, making the gearbox aproxx 10cm longer. this length issue was solved by shortening the diff
samueljon
Post
by samueljon » 07 Dec 2010 10:07 pm
well i would aim to get everything together to make it easier
after going though the "learning curve" stage and getting a little cockey i have to find another one thats all
Post
by Chris_C » 08 Dec 2010 10:41 am
I stand corrected
Never knew that, I've been lucky enough to not own a 4spd
Post
by Ride_on » 08 Dec 2010 02:39 pm
One thing I don't know is if you can use a 4 speed box in a 5 speed, ie leave the 5th gear section in and just replace the main gearbox?
Posts: 4057 Joined: 04 May 2009 11:52 pm
Post
by Speedy88 » 08 Dec 2010 04:25 pm
I imagine not because it must have extra linkages. Could be wrong though, I'm not hot on how gearboxes work.
Post
by volvodspec » 08 Dec 2010 05:14 pm
nope, not possible.
the first 4 gears and reverse can be seperated and used/fit, but the 2 main shafts have different lengths so you need those from the 5spd box..
