Metal shaving sound
Posted: 25 Jan 2011 05:58 pm
by mrborrie
Picked up this partscar last weekend its a Volvo 360 2 liter injection.
Good working engine and tranny just a broken propshaft. when i came at the sleesy cardealer i found her in the back coverd with plants and rusted solid brakes and the owner was nowhere to be found.. this did not look good but i already made a downpayment so i took her home.
So what is this sound.. its less worse in the video than when standing next to it, it gives me goosebumps horrible sound
http://www.youtube.com/embed/wcqZDWQTkVM
Re: Metal shaving sound
Posted: 25 Jan 2011 06:17 pm
by mrborrie
you know i actually was thinking, what is that sound so i went back to check again what the box does.
Well seems when i engage the clutch the sound goes sort of away and when reving the engine it actually does not sound too bad.
Looks like the engine is okay, but i dont get why the prop should make noises when its not in gear
Posted: 25 Jan 2011 06:29 pm
by Speedy88
Sounds like a very very buggered bearing. Torque tube bearing? Also could be bell housing bearing. It will stop spinning when you engage the clutch so explains why the sound goes away then.
Also it could be some splines spinning although I'm unsure how 360 tubes are joined and where.
Posted: 25 Jan 2011 07:04 pm
by volvodspec
Boris, after reading the broken propshaft part; i think you have the problem we're actually busy with on the V3C forum atm; a broken connector piece wich connects the torque tube to the gearbox.
check these for info:
http://forum.volvo300club.nl/showthread.php?t=6715
http://forum.volvo300club.nl/showthread.php?t=6282
Posted: 25 Jan 2011 08:18 pm
by mrborrie
Oh sweet thanks for the info, i'll check it out
Posted: 25 Jan 2011 08:29 pm
by mrborrie
Hmm i actually have a spare of those connector block thingy's
Posted: 26 Jan 2011 12:09 am
volvodspec wrote:a broken connector piece wich connects the torque tube to the gearbox.
I'd go with this one too!
