HMMMMMM tasty
theo2468
HMMMMMM tasty
Post by theo2468 »
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
Re: HMMMMMM tasty
*drooool*. I'd make mine like this if it wasn't for the constant cleaning.
theo2468
Re: HMMMMMM tasty
Post by theo2468 »
I think your wheels are my faviroute wheels at the moment
Re: HMMMMMM tasty
The fact that they just work is what's best about them. All the looks without the hassle of rolling arches. Doesn't even need spigot rings because the bolt holes have angles :D
The only down point to them is that you'll need to hold onto the wheel tight, they will start to pull to one side if you hit uneven ground but it's nothing major, steering remains light. I once let go on a private road to see if it would pull all the way and it will continuously pull left then right then left again, the car still goes in a straight line. The other thing is at full lock they will rub against your mud flaps but again, not a massive deal.
Re: HMMMMMM tasty
I think the tramlining is just down to the width of the wheel/tyre... kinda unavoidable really, I remember mine behaving similarly with 7" wide wheels on 195's
