bonnet for 1989 DL 3dr
I'm after a bonnet to replace the original - which has a largish patch of rust caused by a pool of water when the car wasn't used for awhile and the mounting points? or whatever they're called what holds the bonnet closed....
Anyway the cars a 1989 DL (3door) Vario.... in a (faded) red...
Anyone know what models/yrs have the same bonnet? so if i find one in a scrap yard i will know if its the right one for my car?
Looking for one without any rust/major damage - preferably in red... need to find also what colour code the car is, but its all faded anyway so im not sure what ill do...
...or if anyone has a suitable one? let me know perhaps...
Cheers very muchly
Cheers very muchly
all bonnets after 82 or so will fit. all the reds after about 87 should be the right colour - btw its pretty easy to get that red back to its origional colour - i did it to my mums 440 over the weekend, and that was as pink as anything
i think we proved that wrong before mate..
i got an electric polisher - it runs off 240v mains and cost a tenner from argos (half price sale at the mo). bung some polish (cant remember the brand, but anything should work) onto the pad, put it on the car, went over the bonnet, then took it off. then did the same to the rest of the car. the difference is honestly astounding, and a LOT less work than doing it by hand
Im not convinced.. the cars pre 89 with chrome window trim are a different red to cars with the black window trim (89 on)... if Mr administrator was here he would confirm this5lab wrote:i think we proved that wrong before mate..
You want a polish called 'Auto Glym'..it comes in a white container with a red box on the front. I don't think it's all that expensive, but I know for a fact it's cheaper than T-cut, which in my opinion, does half the job that Auto Glym does.Vario Si wrote:Anyone recommend a reasonably cheap brand of polish that will do a good job?
F983 OHD '88 340DL - Gone but not forgotten
C299 LGF '86 340DL - Variomatic jerkiness
halfords also do their own brand stuff - should work quite well.. i'm not sure how good the colour specific polishes are, but they aren't expensive - £7 or so for a bottle, and it'd last you a lifetime - i'd say to give a car a really good going over (say 2 or 3 times on each surface) uses under 1/4 of a bottle
Auto Glym is ok, but it is needed to redo quite often, it was better before every shop started to sell it.
Simonize or what it is called is good, specially that hard(solid?) wax, some paint renovator first and then that stuff and car shines very long time, but sure it takes a day to wax car with that stuff
Paul Tribley
