1.4 to F7R conversion questions
Posted: 04 Feb 2011 06:47 pm
by jon-ovlov
Several questions I wanted to ask, which I'll most likely find the answer to when I do it, however didn't want to go into the deep end blind!
So here goes
1. My Volvo is a MK2 GL, I remember seeing in the haynes manual somewhere that the subframe is slightly different between the MK2 and 3 versions, is this true? I'm also unsure as to whether the rear mounts are the same or different between these models too.
2. Depending on the case above, will the 1.7 mounts bolt straight into my subframe, and to the F7R? (i.e. Dai's polybush mountings)
3. Will I need the bolts from a 1.7 car for the bellhousing etc, or can I use the 1.4 ones?
4. 1.7 sump gasket, cant find anything anywhere, any suggestions? Also, with the sump, I'm assuming the F7R sump bolts will fit with the 1.7 sump?
Erm, thats all I can think of at the mo, sure theres something else mind
Sorry for the annoying questions
Re: 1.4 to F7R conversion questions
Posted: 06 Feb 2011 12:00 am
by Vermilion
jon-ovlov wrote:Several questions I wanted to ask, which I'll most likely find the answer to when I do it, however didn't want to go into the deep end blind!
So here goes
It's true, you need a mk3 front-engine-support-bar thingy and the sway bar
thus, no, these are mk3
don't know, shouldn't be the biggest problem, just get the ones which fit
the offer/demand section, same as above for the bolts, try and see
Hope it helps a bit
Posted: 06 Feb 2011 01:54 am
by jon-ovlov
Vermilion wrote:Hope it helps a bit
Definatly does! I talked to Dai bout the mounts, he said they would fit, that and ive already bought them. Could always fab something up if it turns out to be wrong.
Posted: 17 Feb 2011 12:45 am
by tomsdubwerks
The Renault sump on my F7P used a sealant gasket so I used sealant when fitting the Volvo sump to it. Most modern cars use sealant there now instead of a proper gasket. Fairly certain I checked in Payen and BGA's gasket catalogues when I worked at a factors and they listed nothing for a 1.7 340.
Sump bolts were the same on mine. Bellhousing bolts were a mix of Renault and 1.4 340 iirc.
BTW Subaru's OE sealant is rated as being pretty good. They use it where my brother works and I hear it'll hold a sump on with no bolts in it!!!! The Ford stuff ain't too bad either that's what I used seeing as I work at a Ford dealer now! Still drive VW's though!(and hopefully my Volvo again soon!)
Posted: 17 Feb 2011 10:47 am
by jon-ovlov
tomsdubwerks wrote:The Renault sump on my F7P used a sealant gasket so I used sealant when fitting the Volvo sump to it. Most modern cars use sealant there now instead of a proper gasket. Fairly certain I checked in Payen and BGA's gasket catalogues when I worked at a factors and they listed nothing for a 1.7 340.
Thanks for that stuff mate, will save me trying to source bolts etc when i get stuck!
What up with the ovlov?
Posted: 18 Feb 2011 01:08 am
by tomsdubwerks
Its just in the final plumbling in stages. Just fuel, cooling, exhaust and wiring to do but I've got a Polo with a valver in it needed the same and the Polo's been a long time in the make and I need it done first lol!
Posted: 18 Feb 2011 01:26 am
by jon-ovlov
ah farynuff! I still need to source the 1.7 bits and plumbing. got the loom and pump sorted though. cant wait to get cracking on it!
Posted: 19 Jul 2011 04:18 pm
by billkent22
Sorry to drag this one back up again but could you tell me which bolts you used in the end?
Bill
Posted: 19 Jul 2011 05:10 pm
by jon-ovlov
I got the bolts with the bell housing I used mate, sorry. I can't give you any measurements at the mo.
