Timing Belt tension/how to test.
Posted: 12 Feb 2011 07:39 pm
by CBA
Pains Manual says "Tension the belt".
What's the tension supposed to be? E.G. Deflection of belt possible by hand is x millimeters --- Green books? this phone wont read PDF, its supposed to but it doesn't.
Re: Timing Belt tension/how to test.
Posted: 13 Feb 2011 12:21 am
by morgan105
7.5mm deflection on the longest run of the belt, or 90 degree twist using thumb and finger with moderate pressure.
Posted: 13 Feb 2011 12:44 am
by CBA
Thank you very much.
Posted: 13 Feb 2011 11:42 pm
by CBA
Running sweet as a nut now, much more drivable, think the timing had been a bit out all along.
Cannot believe the haynes didn't have the tension setting in.
Posted: 14 Feb 2011 11:29 am
360? There is no tension setting, it is performed automatically by the tensioner. You have to push the tension up and lock it while working on the belt, then simply release it to tension the belt under the spring pressure, then lock the tensioner in place with the bolt. Check it again after a few days (just unlock and re-lock the bolt).
Posted: 15 Feb 2011 08:54 pm
by CBA
340 1.7
Posted: 15 Feb 2011 09:00 pm
by CBA
had it too tight at first, got out stephescope and heard whining from the NEW idler, set it to near stated tension, very smooth almost silent running, 100 miles and A.O.K.
