Loss Of Gears
Loss Of Gears
Post by 13431 »
Last night i had all gears until i approached a roundabout went to put it in 3rd and it jumped out of gear and then i had nothing.
jacked it up and found the spring clip was not on the linkage and the pin was missing. managed to make a new pin and put it all back together but now i only have...
3rd, 4th, 5th and reverse.
any Ideas??
Volvo 360 GLT 2.0i
Volvo 340 MK2 (Donor Car)
Volvo 340 GL 1.4 Turbo project
Volvo 340 Gl 1.7 Skid Car/ Battle Wagon
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
One day I'll Buy one that works....Maybe! :)
Re: Loss Of Gears
Post a pic up of the pin you have made, it might be flexing and not allowing the selection rod to move enough over.
Dan
Re: Loss Of Gears
Post by Dan »
it was an alan key that fit pretty tight, it doesnt feel like theres slack in the linkage but theres no differentiation between 1/3 and 2/4
(i helped to make it)
i have a dream... a dream of a weekend not spent underneath a car
a weekend when no nuts and bolts are added to my toolbox
no pushing a car home in the rain
one day perhaps my dream will come true
or mabe im just insane
Re: Loss Of Gears
Interesting, get your mate to sit under the car, engine off and select each gear individually. You'll be able to hear if it's slotting in correctly. With someone underneath you'll be able to see if its works properly too. From there you'll be able to see where the rod that sticks out the gearbox should be when in 1st/2nd. Disconnect the linkage rod and try to change the gears using just a screwdriver through the pin hole. If it's not going in gear, you've found your problem.
If it's not looking different between 1/2 and 3/4 though it sounds very much like linkage issues.
Re: Loss Of Gears
Post by 13431 »
Car is now in a mates garage and he's changing the clutch, he's taking out the linkage and having a look i'll keep you updated for people that may experience the same problem..... sm6
cheers anyway guys :)
Adam.
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
