dizzy cap?
spike4073
dizzy cap?
Post by spike4073 »
ok im doing a lil maintainance on my volvo 340 dl 1.4 cvt (b14 4e)
can anyone tell me what type of dizzy cap these take as the one i got from my local spares shop didnt fit and the cheeky git wont refund me as his book aparently shows that its right for a 340?...... were these made with more than one kind or sumfin?
i keep hearing about delco remy and ducciler?.....
any help greatly apreciated
Re: dizzy cap?
I would have thought it a Ducellier, but I haven't looked anything up...
edit: Having just looked up the Intermotor online catalogue, they give 5 different part numbers and three different makes. Delco / Ducellier / SEV Marchal.
What does the dizzy look like, if you can see if there is anything stamped on the body? (Or post a picture) then I could tell from the pic (Never seen a Delco, but I know a Ducellier and a SEV from ten paces.)
spike4073
Re: dizzy cap?
Post by spike4073 »
aha! thanks.... found some tiny writing stamped on it ...says "ducceller made in france"
guess that ansers my question lol
Re: dizzy cap?
There are certainly different 1.4 340 dizzy caps, pre and post renix being the obvious one. As to whether there are more on tope of that, I've never found it, anything 1989 should be correct but then again how many times do factors get the wrong dates on parts...
Re: dizzy cap?
A Renix cap has two holes to take the screws to hold it down?
spike4073
Re: dizzy cap?
Post by spike4073 »
hmmm that complicates things.... the distributor itself says ducciler on it but the dizzy cap currently fitted is held in place with 2 screws? :S
Re: dizzy cap?
Sorry, when I said Renix, I meant a car with a Renix electronic ignition system, which has a Ducellier cap.
as opposed to the old points set up which has a clip-on cap:
Re: dizzy cap?
Post by volvodspec »
those are the 2 main different ones;
all B14's have a Ducellier system, and in total there are 3 different sets of dizzy/arm
1 set for all the pointed models (and the clipped system, doesn't matter wich brand you take; it'll all fit)
1 set for all the renixed models; (screwed system) B14.3S,B14.4E and B14.4S; with Weber 32Dir carb; this has a 10mm axle for the rotor arm
1 set for the B14.3E engine with; (screwed system) Solex single barrel carb, this has a 8mm axle for the rotor arm.
main rule is to allways buy your dizzy and rotor arm from the same brand/manufacturer (bosch, beru etc) as the height of the contacts in the dizzy varies slightly between manufacturers
Re: dizzy cap?
Post by trabitom99 »
There is a difference among the early B14 pointed systems too, my '80 343 has an AC Delco distributor, which also has a screw-on dizzy cap.
Re: dizzy cap?
now that you say so i have heard of that before, but the green books specify only Ducellier system distributors though. hmm, gonna look a little deeper into it, there must be something you can tell by what's on the engine/car rather than looking at the dizzy
Re: dizzy cap?
The green books mention AC Delco distributors in the tech specs section, B14.1E engines got them from CH 488547-516644. Also the parts catalogue lists different parts for the AC Delco distributor: points, dizzy cap (screw-on), rotor, capacitor and vacuum control unit are different.
My theory is it took up more space, making it harder to remove two of the spark plugs, so they dropped it fairly quickly ... It'd be good to see two B14.1E engines next to each other, to compare the differences.
See also these posts (there was also an SEV Marchal distributor)
http://www.volvo300mania.com/forum-uk/v ... 5&start=20
http://www.volvo300mania.com/forum-uk/v ... f=5&t=2297
http://www.volvo300mania.com/forum-uk/v ... f=5&t=3782
Re: dizzy cap?
trabitom99 wrote:there was also an SEV Marchal distributor)
Cassette points are a steaming pile o' sh**e sm2
