Hi Guys, I'm a newbie on here and have only just joined in the hope of getting some technical advice. I don't own a volvo 340 myself, but my daughters boyfriend does and he has a problem with his OSF suspension. The cup at the base of the spring is rubbing on the tyre and has nearly burnt through it. What could be causing this, as surely, even if a spring breaks, the distance between the cup and the tyre is constant I don't think the cup has dropped, I think the wheel has come up, maybe a bearing or something like that? Any help, as to what I should be looking for, would be very much appreciated, before I drive out to it tomorrow with my jack and tools.
Many thanks in advance
Many thanks for your reply Tom. Can these spring seats collapse and be pushed down onto the tyre by the spring then? I think that must be what's happened
Hi Evoman and thanks for your reply. I think that's what has happened as it went all of a sudden as they were driving home. Will it require new struts or are these seats available on there own?
Ye sounds like it collapsed if it was sudden, I got one off ebay, search the forum should be a link somewhere to the new ones, a company called hadrain i think, tom will know for sure.
You can get a new strut, but they are hard to get as they are prone to rotting, if your spring cup has collapsed it could also be too rotten, but you should be able to see. I had a new spring cup last week, if you can weld (I can't) it is a DIY job.
