How to replace oil in shocks?
Nosher
Post by Nosher »
hey
ive had a quick search and couldnt really find anything, does anyone know how to replace the oil in the shocks?
ive heard that swapping oil in the front shocks to gearbox oil will stiffen them up as it is thicker, how would i go about doing it?
im only gonna be running them like that briefly, untill i can afford some adjustable shocks off dai...
jon-ovlov
Re: How to replace oil in shocks?
Post by jon-ovlov »
If you take off the strut assembly, spring etc, it'll reveal at the top of the strut tube a large nut that screws into the strut. Take that off, the damper assembly out, drain the old oil. Then put the thicker oil in, and put everything back on.
I never replaced the oil myself, but took the strut assembly apart to put Dai's dampers in. Some cars have damper inserts , some (older versions) use the strut tower as the damper housing, so there was no insert.
Hope that helped a little bit. :lol: Theres definitely some one else on here who can give a more detailed run down though!
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Vermilion
Post by Vermilion »
IF you have the shock out of the strut, it could be wiser to replace the shocks for a quality pair
Volvo 340 L 1983
