Will post up a thread for my F7P conversion sometime soon. I've got a quick question regarding the thermostat connections in the mean time.
I've got a Renault 19 thermostat and was pleasantly surprised to find both the 1.7 radiator hoses fitted straight onto the engine, which I don't think was the case for other people (maybe the Clio thermostat is different?).
Anyway I'm now a bit confused as to what to do with the other connections. I've got a small diameter outlet on the top left of the thermostat housing which I believe was the expansion tank connection and a larger diameter hose which goes into a T piece which I assume is for the heater.
Do I need to run the expansion tank outlet to the expansion tank (and drill out the second conveniently placed connection on the Volvo tank or do I blank it off, or should I blank the original Volvo radiator expansion point off and just use this new one?
Similarly what do I do about the heater hoses, do I just put them into this T piece and stick the flow restrictor valve into one of the pipes going into the heater matrix or do something else? I'm not sure if there will be any flow if I stick both heater hoses on the one T piece?
I've attached a picture of my thermostat.
