360 tank strap group buy
Posted: 30 Oct 2011 04:26 pm
I need to get a new tank strap made up, and wondering if anyone else interested. I have one nearly new one for measurement.
Plan is to use a local metal folder, hopefully they can do spot welding aswell, and then get them hot dip galvanised and powder coated in another location. It would be the same as OE but I may leave out the extra bit for the plastic clip for the handbrake cables as these don't really work that well and just put something in for a tie wrap. Or should I go for full original design?
No idea of costs at this point, the gal+coating could be expensive but will get prices and leave it as an option. I'm hoping to do it for say £20 a unit over batches of 10 or 20.
Anyone interested? ..fully finished spec or does anyone want parts and self assembly/self finishing which could be significantly cheaper. Eg I could just sell the folded end for others to source/cut the main part themselves.
Will try to source new sticky foam aswell.
Alternative ideas? Aluminium? Stainless uncoated? would probably prefer to stick with steel, and not do any re-engineering unless someone else is confident it would be ok.
Anyone in NI can collect, could post en mass to a few on the mainland.
