You can see it on the deck in this pic.
The only part I removed in one piece is the valance front section (as I was going to repair this part). I drilled out the spot welds, it will go back on but needs a little work. I also cut the bottom lip off as it was my intention to run the crossmember section open so it would not corrode again. No need now as I have a new front panel.
Really should update my WIP thread too.
