Toughing up the 340
Toughing up the 340
Hi all. Got a welded diff on its way, next on my list is to polybush the engine mounts and lower it. Just wondering what other sort of mods i should be doing to stop it breaking everytime the ass end kicks out?
Thanks
Thanks
Re: Toughing up the 340
erm it wont break if looked after properly like any car and search button is you Favourite friend on here
Attack2001
From what i've discovered, you need to uprate all the engine and gearbox mount bushes, make sure the engine and gearbox output shafts are aligned. Make sure the propshaft is central on each output shaft, and the drivetrain should last through the abuse
Worn engine mounts, welded diffs and lots of clutch kicked i believe is what has brought this "drivetrain always breaks" opinion of the 340's
What would you expect from a 25 year old car on original bushes
So, best get an order in with DAI
Thomas..............
I'm new to the forum and this is my first post but I recently bought a 340 which I plan to track this year. I'm after poly bushes for all the engine and box/diff mounts so can anyone point me in the right direction please. I'm running a 2.0 460 engine in the car (with electronic fuel pumP ) if that affects the bush choice. I don't plan to weld the diff just lower the. At and sort the bushes first.
Attack2001
Search is your friendAlan M wrote:I'm new to the forum and this is my first post but I recently bought a 340 which I plan to track this year. I'm after poly bushes for all the engine and box/diff mounts so can anyone point me in the right direction please. I'm running a 2.0 460 engine in the car (with electronic fuel pumP ) if that affects the bush choice. I don't plan to weld the diff just lower the. At and sort the bushes first.
DAI's Thread - http://www.volvo300mania.com/forum-uk/v ... f=8&t=1804
Cheers for the advice ill have a better look on the fourm
yer its is unfair the car has got this rep as it is expecting a 20yrs+ old car to not have worn parts is just unreal
I understand the age thing, mines coming up for 28, i was asking what things i can do to prevent things breaking due to too much stress etc.
Cheers for the reply. I spoke to Dai today and I will take quite a few parts from him but I going to strip the car first then order the parts.
Attack2001
Sweet, another 340 getting the treatmentAlan M wrote:Cheers for the reply. I spoke to Dai today and I will take quite a few parts from him but I going to strip the car first then order the parts.
Hairy muff dudemat_91 wrote:oh that wasnt a dig as a much just a general moan at people lol
