F7P 340 Dies Turning Right
Hard right turns the car stalls, proper stumped me ?
Re: F7P 340 Dies Turning Right
Do you mean a long sweeping corner or a short sharp turn?
If it's the former, then perhaps you're uncovering the fuel pickup and it's being starved
Trundle returns... Watch this space
The latter.
Dodgey wiring loom whoever installed it !
then i'd imagine the wiring is getting snagged on the steering.. have a look behind the column shroud
Wiring doesn't seem to be snagging on the column anywhere, been told by a local Volvo place to check the plugs under the fuse box?
Also, the MAP sensor plug looks dodgey.
Bloody cars.
Bloody cars.
whereabouts are you? maybe there's a member nearby that can help
Sorted.
Whichever monkey fitted this f7p needs words ! Coil pack low tension wires just twisted together...
Rough as toast.
Think I needs a valver loom and start a fresh !
Rough as toast.
