Idiots guides to fitting polybushes to the ARB (10pics)
Posted: 19 Jun 2005 08:22 pm
First, take one village idiot and his car............
Second, find location of antirollbar and it's mounts (hint - try looking between the front wheel and the front of the wheelarch!)..........
Next, remove engine undertray (if yours still exists). 8 10mm bolts and 3 clips holds it on. Jacking the car up slightly so wheels do not leave the ground helps access. This is what you should see (oils stains optional....).........
Use a 13mm socket to remove the two bolts holding each bush on....
Remove the metal 'U' piece and bush from the car........
Note how the new polybush (for an Amazon) is slighty different in design to the 360 one...........
Fit the new polybush.........
Refit the 'U' clamp and tighten up the bolts to a setting of 'F'ing tight'..........
It should end up looking like this..........
Repeat procedure on the other side and end up looking like this.......
Refit undertray, and lower car to ground.
Go for a spin..............
