whats happend here
whats happend here
right..... under the exhaust manifold and to the left a lil bit theres like a rod with a plastic joint at the bottom and then another joint at the top and its like exploded theres horrible thick fluid everywhere
Re: whats happend here
are you, like, someone like, who says "like" every, like second? kill ALL the likes!! do not use them!
to answer your question, yes, pics would help a lot. we ll be able to determine what is wrong then.
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
this looks to be where all the mess has come from but i dont know what its called
What car is it? Looks like the steering column, AFAIK there is just a rubber damper insider. Is it power steering fluid or something. Nothing I'm aware of.
Looks like a custom exhaust, and you have some posts about an FP7. Need more information.
its not the exhaust its the black bit there with the plastic bits on the end its like a gritty fluid and its as if its exploded coz its everywhere
could you circle it on that image please? i still can't see where you are on about.
Rev engine to 7K
Win at life.
Like ride_on says its looks like its the steering column, I think he was also asking about your exhaust.
Its probably gritty becuase it now has road dirt mixed in
yh i think your right about the steering colum why has all this liquid come out?
looks like PAS to me as the non-pas has no UJ there and a different heat sheld. check your power steering fluid resevoir, does the steering feel hard?
im pretty sure i dont have power steering though
is there a lot of fluid then? if its gritty its probably just old oil thats pooled, or an oil leak somewhere.
have you stuck your finger in it? if its black its most likely oil. PAS fluis is normally red or purple. if you dont know you have powered steering, chances are you dont have powered steering. it was AFAIK quite rare on these cars, and if yours is engine swapped, it probably no longer has it if it did.
Rev engine to 7K
Win at life.
or could be brake fluid. the master cylinder is above the steering shaft.
Rev engine to 7K
Win at life.
That looks like a manual steering damper in a steering damper housing to me
