My old '88 dash had metal inserts for the windscreen demister vents, that bent round under the dash too keep them in. On my new dash which is '83/'84 I'm missing these inserts but the '88 ones don't fit. There is a bent bit of metal on the inside of each hole screwed in to the dash, I guess keep the inserts in. I'm also missing the Right hand vent and on/off slider thing. It's the lever type not the gear type, thicker slider and shorter hole in the front cover
More parts wanted:
For my new gearbox,diff I'm refurbing:
Gearbox 'front' cover, the one that the input shaft and selector rod go through, for 360 (m47r if it makes a difference) Got a snapped torque tube bolt rusted in mine that is being rather stubborn, unfortunately it was drilled before i got the box and wan't drilled central so it makes things complicated. So a spare one cheap would be nice.
Also a diff cover in good nick again from 360 glt would be nice as the one on my spare one is rather knackered.
If anyone has them, let me know
Matt
