340 subframe/front suspension crossmember on a 360
wiganer31
Post by wiganer31 »
is a 340 front subframe/front suspension crossmember/Front axle member (what ever its called) the same as a 360? managed to snap mine
i know were theres a 340 for parts so if it will fit it could save me alot of time and coin
Re: 340 subframe/front suspension crossmember on a 360
Post by volvodspec »
how did you do that, hit something?
yes they are the same, only difference is the rear engine mounting brackets of a 340 that are bolted on; they simply bolt off.
wiganer31
Post by wiganer31 »
was on track drifting and i span out, i didnt hit anything and there was no bangs or bumps etc but when it came to the next corner it was pulling towards the wall, must have been going for a while and that just finished it off, now i think about it i have been saying something didnt feel rite for a while but could never find anything,
cheers that's good to know will get on it asap
Nimminz
Post by Nimminz »
when you find a replacement maybe look into this: http://www.volvo300mania.com/forum-uk/v ... e&start=15
Would stop it happening again maybe? Although i'd guess that it's just been rusting with age rather than a defect in design, but still, worth doing
wiganer31
Post by wiganer31 »
Nimminz wrote:when you find a replacement maybe look into this: http://www.volvo300mania.com/forum-uk/v ... e&start=15
thats strange because thats more or less what was in my head apart from welding up the original seams, cheers foe the link mate not seen that before
