tightening track rod end
frazeb
Post by frazeb »
how do you tighten it fully, it just keeps spinning round
Re: tightening track rod end
Post by bogbasic »
Hello, some some of the track rods have a bit with a hexagonal cross-section which you can pop a spanner onto but failing that then I guess mole-grips would do it or I think I used a whopping pair of water-pump spanners for mine.
frazeb
Post by frazeb »
the answer to this problem if any one ever needs is to jack the track rod end up from the bottom
frazeb wrote:the answer to this problem if any one ever needs is to jack the track rod end up from the bottom
Thats the one! Aswell as clean the threads and lubricate.
