Page 1 of 2
B172k - Engine required
Posted: 21 Jul 2012 11:01 pm
As above, I'm after a B172. Realistically I'm after a good one, so anyone thinking of doing a valver conversion is probably a good starting point.
I would preferably like it untouched, i.e. sump still on. I can provide another sump if you are doing a conversion.
I'd also like to see/hear the engine running, I'm fully aware of what most 1.7's are like. This will likely make this local-ish only. I can help with removal of the 1.7 afterwards to be able to run away with it. If this constraint stops things from happening, I might look at casting a less picky net in a few weeks.
Many thanks all
EDIT: Ancillaries. I'd be interested (neh, requiring) things like manifolds, downpipe, carbs, choke cable. I can't remember if I still have a 1.7 renix about either :s. Imagine someone got bored with a valver and wanted to go back to a 1.7 and you'd be along the right lines for what I need.
No, I havn't got bored with a valver....
Re: B172k - Engine required
Posted: 22 Jul 2012 10:01 pm
by J340GLT
but....
Posted: 23 Jul 2012 12:22 am
by Hell Driver
Can't be many 1.7's left now, they've all been valvered
and the engines weighed in
I'll let you know if I hear of one.
Posted: 23 Jul 2012 01:37 pm
but....
No buts
Just an ongoing project I have that would be more suited to a B172 than the F7R. I'm almost tempted to not, but if a nice one comes up it seems silly to not make use of it.
Posted: 23 Jul 2012 09:47 pm
by volvosneverdie
Chris_C wrote:
No buts
Is this your Turbo project, actually going backwards now Chris?
Posted: 23 Jul 2012 09:50 pm
by macplaxton
Sod it Chris, just get a F8Q and be done with it
Posted: 24 Jul 2012 09:22 am
volvosneverdie wrote:Is this your Turbo project, actually going backwards now Chris?
Nope, it's for Fake, it'll be easier to explain when I've done it!
macplaxton wrote:Sod it Chris, just get a F8Q and be done with it
NO DEVIL FUEL!
Posted: 29 Jul 2012 12:17 pm
Bump...
I did start making a list the other day, but lost it now...
Engine
Manifolds
Carb, airfilter
Downpipe
Renix
TPS
Choke cable
Throttle cable
etc
Posted: 29 Jul 2012 12:52 pm
by mattywatsit
Chris_C wrote:Bump...
Engine
Manifolds
Carb, airfilter
Downpipe
Renix
TPS
Choke cable
Throttle cable
etc
Is it not worth waiting for a 340 with poor bodywork but good mechanics to break?
Posted: 29 Jul 2012 11:14 pm
Possibly, though with the prices of 300's recently I'm not convinced!
Worst case I'll just use the F7R I have
Posted: 01 Aug 2012 08:01 pm
by mattywatsit
Chris_C wrote:Possibly, though with the prices of 300's recently I'm not convinced!
Just spotted this Chris,
http://www.gumtree.com/p/cars-vans-moto ... /107965594
Matt.
Posted: 01 Aug 2012 08:05 pm
Thanks bud, worth an investigate
Posted: 04 Aug 2012 02:10 pm
by Attack2001
I've got one, I'll write more when I'm off this poxy phone haha
Posted: 04 Aug 2012 10:13 pm
by Attack2001
Right, i've got a 1700 under the bench. its got the sump and mounts with it etc, however i want to keep the sump, mounts and bellhousing as i want to go 1700turbo at some point too
If i recal correctly its out of a 100k car. The fuel pump has been snapped off though so you'll need one of those. Its got the flywheel with a clutch. Its got a brand new downpipe. i have a spare carb for it too. Its got a new-ish set of plug leads on it. Cant say much else really, i took it out of the car and slung it under the bench as i was going to convert mine but decided theres no point doing all the work for 10hp. Any use to you?
Thanks, Thomas.................
Posted: 05 Aug 2012 11:51 am
Give me a day or so to ponder chap, might well be but I'll have to have a work out what else I'll need to add to it! Ta muchly!
