Front coil springs - Replacement
kelvingenders
Does anyone know when these need to be replaced. My 360 GLT seems to be very noisy at the front. I have replaced all parts, bearings, track rods shocks etc, but there is still a big thud when I go over bumps. Could these be knackered, or is this just the model!!
Re: Front coil springs - Replacement
Chances are the springs have sagged. What shape are your dampers in? Worn out dampers will cause a rough ride.
What are teh roads like where you are?
kelvingenders
Brand new dampers - gas ones from scandix
Do you have bump stops fitted? Is the thud from the spring full compressing?
kelvingenders
Bump stops fitted and new
ARB link rods? The later versions with ball joints attached under the spring plate do get worn after 100K or so and clunk over bumps.
I can't imagine it is the springs unless they are broken, even then it should just drop.
kelvingenders
link rods are new...have ordered new springs
kelvingenders
Have taken the ARB link rods off. The car is much, much, much quieter. I'm replacing the poly Control arm bushes with rubber ones. I think this is also where a load of noise is coming from. Problem solved with money ...again
