e36 open drift championship car
Bodyman
Post by Bodyman »
Spec as follows
1.8 on v5
Full recent respray in Ford Frozen White ( Tranny Van white )
Engine covered about 130k, solid as a rock engine, being the 2.5 M50 None-Vanos it is highly regarded as the best engine for a drift car baring the S50 ( M3 engine ).
Hydro handbrake (locks up perfect)
Short shifter
Trs tow strapon the rear
Small case welded diff
Chipped ECU so revs to 7.5k and really makes a difference
12mil wheel spacers on the front
Hot tuning coil overs on front (fitted when i done the conversion)
Bilstein b4 rear shocks fitted about 2k ago so like new and hotunning lowering springs
New prop shaft donut less that 1k miles ago
New diff mounting bush fitted less than 500 miles ago
Steel water pump
Lower temp 82 degrees thermostat
Elec fan on a switch so can be run alongside the viscous which is pefect, (this car can be drifted all day on track and temp doesnt move above half way even in the boiling sun.
New sachs clutch fitted 7k miles ago
M3 eccentric bottom arm bushs providing better turn in.
Momo Race steering wheel and boss cost over £150 quid new
New front drop links fitted 3k ago
Leather Front Seats
Mot till october 2013
Tax till the 31st March 2013
New Windscreen fitted in Sept, lifetime guarantee with Autoglass
16" Wank MOMO alloys.
Rear of car all stripped.
Bad points
Rear bumper cabletied here and there.
Bonnet bit rusty underneath
rear arches bit crusty inside
throttle inlet pipe split, one on order, if it shows before it goes it'll be on, just means it idles badly when it's first started in a morning!
Dont want cash money really, more swaps with money aswell if need be, but if you just wanna buy it out right i want £1600, fair price really considering it's good to go for the ODC next year, i just never reallly liked it, prefer something with less power, so will swap for a well specced MX5, or a well specced Volvo 340, money either way for right car, but not too much, skinto.
Best to text me - 07786031354
Before respray;
All damage repaired /\ That wall at Buxtons frigging hard!
After the respray;
