S14 coilover conversion
PISTONMELTER5
Post by PISTONMELTER5 »
Is it the front or rear s14 coilovers you use to convert the front of the volvo to coilover suspension?
been looking through a few threads and have seen a one say front and the other say rear :?
What exactly needs doing to convert them? is it just a matter of grinding down and welding the s14 ones to the volvo hub? :?
any clarification would be appreciated!
Re: S14 coilover conversion
In short you dont.
When converting to coil overs you can use the nissan top mount
wiganer31
Post by wiganer31 »
As above, you can either send your volvo shocks to gaz or make your own, evenythings in here really http://www.volvo300mania.com/forum-uk/v ... =5&t=13528
PISTONMELTER5
what i was planning was to use the s14 coilover itself! As a mate has a set cheap i was planning on machining out the steering knuckle ever so slightly so that the s14 coilover fits into it and then weld it up so its all nice and secure, was then going to extend the original strut tops by about 2 inches so ive a good bit of adjustability and then redrill it to fit the s14 top mount bolt pattern as you would have to do anyway when extending the turrets :)
Attack2001
Post by Attack2001 »
PISTONMELTER5 wrote:what i was planning was to use the s14 coilover itself! As a mate has a set cheap i was planning on machining out the steering knuckle ever so slightly so that the s14 coilover fits into it and then weld it up so its all nice and secure, was then going to extend the original strut tops by about 2 inches so ive a good bit of adjustability and then redrill it to fit the s14 top mount bolt pattern as you would have to do anyway when extending the turrets :)
Search nikdev, i remember him using a set of s body coilovers in his 300 :)
Thomas...........
