Page 1 of 2
STARTER MOTOR MAKES A CHOKING SOUND?
Posted: 21 Dec 2012 05:46 pm
by Justin
I recently replaced my old starter motor with one from a scrappy, it starts fine but initially makes a short, sharp choking noise. I spoke to a friend of mine who used to work at a local main volvo dealer back in the day and he suggested removing it and putting some oil into the opening part that connects to the car?
Re: STARTER MOTOR MAKES A CHOKING SOUND?
Posted: 21 Dec 2012 05:49 pm
I take it the starter gear is not returning on release of the key by the sound of that. Check how freely it will slide and a bit of light oil on there could help.
Posted: 21 Dec 2012 05:58 pm
by Justin
classicswede wrote:I take it the starter gear is not returning on release of the key by the sound of that.
That's exactly what's happening... Will try some oil on it when I can be arsed!!
Posted: 22 Dec 2012 11:35 am
by thebear54
It may not be just a lack of oil...but start there.
A few months ago I had a starter doing the same as described.
I removed it and behold the bronze bushings at each end had deteriorated to the point where the starter shaft was cockeyed in the housing.
A good cleaning and replacement bushings later the starter is new again.
John
Posted: 28 Dec 2012 04:24 am
I've no idea what a choking sounds is, but you can strip it down fairly easily, maybe swap over the solenoid from your old one.
Posted: 28 Dec 2012 02:12 pm
by Justin
Is the solenoid the small cylinder like drum that sits on the top of the bulkier main unit?...
Posted: 28 Dec 2012 02:37 pm
thats it
Posted: 28 Dec 2012 05:50 pm
by Justin
Why would it make a difference swapping the solenoid as the spare one I have is on my old starter motor which completely stopped working a few months back?
Posted: 28 Dec 2012 08:16 pm
by pettaw
I don't think that swapping the solenoid will help you all that much. TBH I reckon you need to strip the entire starter out and see what's happening.
But before you go to all that trouble, just make sure the starter is in completely straight, and there's no rusty bits on the mating surfaces between the starter and the clutch housing. If the starter and the flywheel are very slightly out of alignment then the Bendix gear might be jamming slightly and not slipping back out as it should. Its unlikely but worth checking because its a lot easier than trying to take apart the starter.
So apart from that, you'll need to take apart the starter and start checking bearings for play and float. If its been off a car for ages or sat in a scrappy getting damp and rusty, no knowing how much rubbish is in the places where nice shiny metal should be, so you might need to strip the whole lot down clean off all the old sticky oil/grease and re-lubricate it properly.
Good luck.
What was wrong with the old one? Can you swap parts about from the two duff ones to make one good one?
Posted: 31 Dec 2012 04:40 pm
by Justin
To be honest with you I wouldn't know how to strip a starter motor down. Im gonna try re-aligning it and then if that doesnt work just live with the noise until it packs up completely and then get another one from the scrappy...
Posted: 31 Dec 2012 08:23 pm
Check for play in the bushes or you will end up shreading the starter ring on the flywheel.
Posted: 01 Jan 2013 12:12 pm
by thebear54
classicswede wrote:Check for play in the bushes or you will end up shreading the starter ring on the flywheel.
That's what I said earlier :wink: :wink:
I took mine to a rebuild shop, because I also do not have the proper knowledge. $ 80.00 and within two days it was returned in perfect working order.
A complete service to the windings, interior cleaning, installed new bronze bushings at both ends, bench tested the bendix/solenoid operation and repainted the outside...
Plus I received a full year warrantie on the work. :D
John
Posted: 01 Jan 2013 01:00 pm
by macplaxton
I know that's on a 1108, but is there (I can't see) anything holding up the right-hand end of the motor in the picture there John?
Posted: 01 Jan 2013 01:59 pm
by thebear54
Not supposed to be anything holding up the right side of a starter Rich.....3 bolt mounting at the bendix side only. :D
John
Posted: 01 Jan 2013 02:35 pm
by macplaxton
thebear54 wrote:Not supposed to be anything holding up the right side of a starter Rich
You knew this was coming back to bite you on the ass....
DAF66_starter_motor_111034_support_225413.jpg by macplaxton, on Flickr
Please tell me what bracket #28 is and what it does? :lol: :P
They are long AND heavy those old long-case starters, the pinion gears on them however are not as deep and they don't seem to suffer from the "stuck in mesh whine" that the later short-case motors do.
