The prop should sit parrel to the car shouldn't it?
Mine at the minute rakes down towards the gear box which is most likely why it ate the prop?
Quick prop question
Re: Quick prop question
soun
ds like the rear mounts are saggy, are they still original?
Can you get a photo?
Could also be if the front engine mounts are too squashed, or the mounting bar is bent, or the suspension crossmenber has been pushed up.
If the mounts are loose/soft/torn the driveshaft and gearbox will want to the twist up like a rope.
samburgess
Dai I just put your engine mounts in so I think the engine had just sat a lot higher than it used to that's all
Just wanted to make sure my new prop went on as flat as it could go
