Kelvin
Dip stick tube removal
kelvingenders
Hi all, I've got oil leaking from the bottom of the dipstick tube...where it connects to engine sump. Is it easy to remove. Do you need a special tool, or does it unscrew. Is a leak from this common or have I got a wrong diagnosis on the B200 redblock
Kelvin
Kelvin
Re: Dip stick tube removal
Has a small O ring on bottom of tube. Has one single 10mm bolt somewhere up the tube off a bracket. undo that, pull tube out fit new O ring should be golden.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
kelvingenders
Always a pleasue logan
No prob. was pulling something out of my parts car and that ended up coming out so i examined it. turns out i remembered lol
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
kelvingenders
Turns out there was no o ring!!. Probably part of the problem.....have put 10 mm x 2.65 mm one on.... Hopefully this sorts the leak
