343 cluster
343 cluster
Hey guys have been asked if a 360 cluster will fit a 343. as i don't think they are the same if anyone has one can you post year/price/post to new zealand? thanks guys.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: 343 cluster
Eh? What? Is it Thursday? I'll have chips please.
Light cluster, instrument cluster or some other cluster?
Re: 343 cluster
Hi Logan.
There are four different types in the 15 year production run.
Need to know the year of the car.
76-78 78-82 82-85 85-91.
Re: 343 cluster
Sorry guys instrument cluster. and I'll post year asap. anyone have approx prices etc?
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: 343 cluster
Ta for the finer info.
Mark must have the uncanny ability to read minds.
There's sort of more than four, because for example the 1.4 MY79-82 instrument panel can be found it at least three versions.
If you're prepared to do the wiring and get the right senders (ir required to match the panel), then basically there are two dashboard holes. Up to MY82 and MY83 onwards. But life is a lot easier if a set of clocks from the appropriate year are plonked in as all the sender units will be correct as will the speedo cable connector.
Re: 343 cluster
Hey guys more info. its a 81 343 and he's after the cluster surround eg with the light switch and demister switch. my cars a 87 360. anyone know if it'll fit? if not does anyone have a spare?
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: 343 cluster
The cluster surround does not have a light switch / demister switch attached to it... It might appear that way on a late one, but the switch is miles away on an '81.
Tell the guy they're made of unobtainium, because it's not for a car...
Re: 343 cluster
Not for a car?just saw your pm. it's the bit tat holds the cluster assembly in the dash. on a 360 it has fog light rear demister and headlights attached to it.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: 343 cluster
I know the part you mean on a 360, but it doesn't exist on a 1981.Logan360 wrote:it's the bit tat holds the cluster assembly in the dash. on a 360 it has fog light rear demister and headlights attached to it.
Here's a 360 Smiths panel from a 1983 car.
DSCF2138 by macplaxton, on Flickr
The surround holds the cluster in place along with a metal strip.
This is completely different to the earlier cars, which have two screws that screw straight into the dashboard aperture and hooks in at the bottom.
DSCF5667.JPG by macplaxton, on Flickr
There is no surround that holds it in. THERE IS NO SURROUND THAT HOLDS IT IN!
The only "surround" that those instruments have is the actually a plastic housing that holds the clocks / circuit wiring / dash lamps.
Re: 343 cluster
Ok thanks for the pics. i have no idea how 340's are as i didn't think we had them here but that helps thanks.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: 343 cluster
Hi Logan.
When i get time sometime this week, i will take a few pics of the dash on my 1981 Banana.
The light switch is down to the right of the cluster.
